Who was it who mentioned Fram oil filters and dropping oil pressure?
  • Start date
They were all the same pump, regardless if it used the long or short
filter.The standpipe was long untill 1972 so the older engine could
not use the PH43 - only the PH8A (or equivalent) (Long filter)
Yes, but you have no way of knowing what part was on the car in
question. The guy who owned the car doesn't know what it had.
The FL1A Motorcraft filter is a direct fit replacement for the PH8A
and has a VERY superior construction. The Napa Gold filter is almost
as good and around heare costs more. I believe the FL1A used to be
called the FL30001 - and it had a double sealed drainback valve .
There is no valve in the standpipe - or al least there wasn't in the
63 170, the 65 225 or the 69 225. (long standpipe) and I never had
problems using the long non-fram filters on ANY of my Mopars.
Well your missing valve would explain why you were having problems.
But I suspect you were just unaware that the valve was there and quite
likely if you had problems with the oil draining back then the valve was
not functioning properly. Again this is something ore likely to happen
in an old dirty engine. I was not aware there was a check valve in the
outlet, but I never encountered the problem so there would be no reason
to be looking for a cause. It does make sense that this type of design
would need a valve in the outlet.
I found 2 sources that describe the part as "oil filter standpipe
w/valve".
And another popular mechanics article describing what what happens if
the valve sticks in the closed position:
http://tinyurl.com/yakqhxz
-jim
Well if it was rebuilt it wasn't new and likely wasn't anywhere close to
being like original. Are you talking about a slant six engine?
How do you know what it was like? And what would rebuild tolerances
have to do with an anti drainback valve working or not?
The engine was close enough to original to run like a new
original engine. It still runs like a new engine.
I don't know what else you want to hear. And actually I don't care.
And no it was not a slant six. It is a Ford 300 six with the filter
mounted horizontal to the side of the engine.
It's kinda suspicious that you can't keep your story straight.
Previously you said Fram was used right after the rebuild. Now you make
it sound like  you used other filters and used the Fram much later. You
know anyone can make up a story and tell it on usenet.
Yea, and anyone can be a horses ass on the internet too..
I used the fram filter about 5000 miles or so after the rebuild.
I consider that right after the rebuild, and the reason I said
that was you were implying that my engine was a beater and
all crudded out. It was not. It was a very clean engine.
I used only motorcraft FL1A's except for that one time when I
used the Fram which I got free, was laying around, and I decided
to try it even knowing about the anti drain valve problem.
The damn thing flaked out on me that very night and I had
trouble building oil pressure after cold starting. Which it had
never done using the FL1A. Ever!
I took the damn thing off that night and replaced it with a FL1A
and never saw the problem again. PERIOD!
If you like Fram filters, use the sorry things. I won't, and I don't
care if it chaps every whiny asshole named Jim from here to
New York City.
Anyone that actually has a clue is familiar with the problem.
I knew about it before I tried it, but curiosity got the better of
me and I wanted to see it for myself. I did see it, and I won't
ever use one again.
Like I said, it's not something I just made up. Like one said,
you've never seen the problem, so according to you it can't
exist.. What an asshole... :/
I'm through with this thread. I've covered everything I need
to talk about concerning sorry Fram oil filters.
And I'm sure had my fill of talking to a horses ass.
You tell me that. Your the one claiming there is some sort of oil
pressure problem but you haven't explained the circumstances with enough
clarity for any one reading it to determine anything. The only thing you
have said that sounded clear and reliable is that that you hated Fram
filters before you even tried the first one, and that you tried that one
filter on a fairly old engine which you rebuilt. That is hardly the
mountain of evidence you seem to think it is.
Yes it is something you just made up. You do not have much evidence.
Your tale is one rather poorly remembered single incident. I have seen
engines with various types of oil pressure problems and most of them
were not using Fram filters.
Nobody denies there is a lot of Fram detractors on Usenet. That is a
fact - no one doubts you can find people who agree with you. But if the
only evidence you can muster is everybody else says the Fram filter is
bad - that is no evidence at all.
I don't claim Fram filters never fail, but I know that anyone who
claims they always fail is simply lying. Studies have shown that the
failure rate for the drain back valve on Fram's is no different than
many other brands.
It may come as a surprise to you but brand new engines sometimes fail.
Read the following from a service technician that spent 35 years looking
at the problems that can occur with Ford engines under warranty"
***** START QUOTE******
For many years I worked in Ford Quality Services Dyno. Part of our
responsibility was to disassemble dealer return 4.6 and early 5.4
engines from across North America. These were noise concerns,
catastrophic failures, you name it. Engines that were pulled from
customers vehicles under warranty. We had engines from everyday drivers,
taxi, limo, police, raceing, delivery service, etc. I think I can safely
say I have seen it all when it comes to engine failures be it abuse or
other wise. We dissasembled, analized, and wrote reports on our findings
and determination on root cause of failure.
All filters be it air, fuel, oil have the potential to induce
contamination from the very material it is constructed of. The very
filter material that is designed to remove contaminates can breakdown
and migrate into down stream engine components. Any filter regardless of
manufacture has this potential. We have seen this with Mass air, fuel
injectors, oil passages ( restrictors). it happens because anything
mechanical has the potential to fail.
We would write reports based on our teardown analysis of the failed
engine. This report would be used for determination of warranty approval
or denial. I cannot remember when a warranty was denied because a
specific brand of oil filter was used. Now I've seen failures where we
found the original factory oil filter still on the engine after twenty
to sixty or seventy thousand miles and this was noted in the report. A
much bigger factor for warranty claim is regular maintainance with
receipts/records intact. I simply do not believe a dealer has the legal
right to deny a claim based on what brand of oil or filter the customer
used. I personally have never seen this happen. We would get police
vehicles with blown engines from high speed chases. The records would
show they used some off brand filter with bulk oil but had regular oil
changes at recommended intervals. They still were covered under
warranty. I have recieved failed engines with every brand or off brand
oil filter you can imagine and it was not a determining factor of
warranty denial or acceptance. Keeping receipts and maintainance records
for each vehicle is paramount.
Therefore the Fram versus Motorcraft debate in my opinion is mute. I
have used Fram as well as motorcraft and others. If I have a particular
concern ( start up knock for example) with one over the other then I
stick with the one I have confidence in. I have never seen a warranty
denial because a Fram filter was on the engine or as I stated any brand
filter for that matter.
This is just based on my experience. I don't claim to know everything
about this topic. But I know that Ford does value a customer and tries
to satisfy them. After spending much time also as a dealer panel rep I
can tell you there is always two sides of the story to every warranty
claim. The dealers and the customers. I learned not to make any
judgement until I heard both sides. You would be surprised how the story
can change once you get everyone in room together....
If you are abusing your vehicle or neglecting regular maintainance they
can and will decipher it and you very well may foot the bill on a
failure replacement or repair. If not then the dealer should take care
of you regardless of the oil filter brand.
***** END QUOTE******
Hachiroku said:
<SNIP>
Oh, yeah. I forgot. You guys already had your Thanksgiving...
Indeed.
Had a CAnadian supplier call me yesterday. I guess it was "thursday" to
him.
nate
(pecan pie for breakfast! woo hoo!)
If I believe what you believe I would not buy a Fram filter.
<snip>
Hachiroku $B%O%A%m%/(B said:
We'll see what happens after I change the Soob filter...
The test will only be meaningful and valid if you go to the dealer and
get the manufacturers recommended filter.
<snip>
"Jim" and "Mike Hunter" are the same person? It all makes sense now.
nate
It's a known problem on the orange Fram filters. The problem is the
anti drainback valves don't work. How much it effects the engine will
depend on the filter mounting and position.
It's the Fram ExtraGuard filters (their low end product, orange) that
has the problem with the anti-drainback valve.
From "http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilters.html":
"The rubber anti-drainback valve seals against the cardboard and
frequently leaks, causing dirty oil to drain back into the pan. The
bypass valves are plastic and are sometimes not molded correctly, which
allows them to leak all the time. The stamped-metal threaded end is
weakly constructed and it has smaller and fewer oil inlet holes, which
may restrict flow. I had one of these filters fail in my previous car.
The filter element collapsed and bits of filter and glue were
circuilating through my system. The oil passge to the head became
blocked and the head got so hot from oil starvation that it actually
melted the vacuum lines connected to it as well as the wires near it."
That story is not believable. Here is why it is not believable: If you
read the warranty from any filter manufacturer they will cover damage if
such an event would occur with their filter.
So why didn't this guy get a replacement engine from Fram?
Because what he claims caused his engine damage never happened.
What probably happened is this guy ran his car low on oil and destroyed
the engine. Rather than admit it was his own fault he creates this story
which blames it on the bogey man. Others are more than willing to repeat
the story as if it were truth.
There are plenty of stories of people who use Fram filters for very
long lived engines. The guy who puts 400K on an engine and maybe
installs around 100 filters on that engine doesn't seem to ever run
into a bad filter. But the guy who used a Fram filter just once in his
entire life tells a story of how they destroy your engine. I'm sorry I
just don't find that believable.
If Fram filters disintegrate like this story claims - Why can't you
come up with lots of cases where car manufacturers get Fram to pay for
replacement engines? Or how about come up with just one case. I mean
this pretty cut and dried - if they are at all prone to disintegrate
wouldn't it surely show up on the one of millions of instances where low
mileage new vehicles had a Fram filter installed?
-jim
LOL, those warranties are all bogus. Just try proving that the damage
was a direct result of the oil filter. Often it's latent damage that
isn't apparent for tens of thousands of miles (or more) of start-ups
with no oil caused by a crappy anti-drainback valve/
It's a similar issue with non-API certified oils where they guarantee to
cover vehicle damage caused by the oil. Good luck proving that your
early catalytic converter failure was caused by the high level of ZDDP
in the oil.
What's ironic is that it's probably the same people throwing away money
by doing 3K oil changes that are also buying the worst quality filters.
That is what independent claims adjusters are for
Or maybe its just the bogey man out to get you.
in the oil.
No its not at all the same. Using non-certified products will void your
warranty. If Fram filters disintegrate then the automakers would have
literally thousands and thousands of claims against fram. There would be
class action lawsuits. It wouldn't just be rumor and superstition on
usenet.
The people I know who have the longest lived engines use Fram filters. I
know a guy who bought a new GTO in the mid 60s when he got out of the
service and still drives it today. He claims his secret is to change the
filter every 2000 miles and change the oil every other filter change.
The engine is pristine and never had a problem. Just about everything
else on the car has been replaced or rebuilt. But you are right if you
aren't going to be willing to deal with the rest of the car there is
little point in doing the maintenance that keeps the engine running good
that long.
-jim
Ah, I didn't realize that, but it all makes sense now as both seem to
equally clueless, and now both are equally in the kill file.
Sure if one bogey man story fails to support your superstitious
beliefs - just create another bogey man story.
Puleeze. They're obviously different folks.
And you will killfile somebody because they might use Fram oil
filters?
Oil filter fanaticism to the extreme!
--Vic
filters?
--Vic
Well, I didn't see "Mike Hunter" posting to this thread before, although
he seems annoyed that he has "had his fill." And "Jim's" posts are
every bit as opinionated and full of himself as I've come to expect from
"Mike." So they may or may not be the same person but I thought that
"Mike" was implying that he was "Jim."
In any case, this has gone on far too long, and "Jim" certainly seems
every bit as pleasant to interact with as "Mike" and as immune to facts
that don't fit with his preconceived worldview.
nate
jim...jim beam?...oh,brother...now infecting groups other than Honda?
Jesus ever let you put your finger in the holes in his hands, and your hand in his side?
Once more, for the fans on the West Coast...
1988 Supra. Bought in 2004. Oil changes every 3,000 miles since I have
owned it. Approaching 30,000 miles since I bought it.
1989 Subaru GL coupe. Bought in 2007. Oil changes every 3,000 miles since
I have owned it. Approaching 20,000 miles since I bought it.
1989 Mazda 626. Bought in 2006. Oil changes every 3,000 miles since I
have owned it. Approaching 30,000 miles since I bought it.
1985 Toyota Corolla GTS. Bought in 1986 with 10,000 miles. Oil changes
every 3,000 miles. Now has 259,810 miles. (that's 86 oil changes, all done
by me) Hey! 86! I like that number!
1992 Dodge Caravan. Bought 2 weeks ago. Did an oil change. Will do an oil
change every 3,000 miles as long as I own it.
2005 Scion tC. Bought in 2006 with 11,000 miles. Oil changes every 4,500
miles, since I use synthetic in this car. Approaching 20,000 miles since I
bought it.
No, I do *NOT* analyze my oil. I just change it. Period. Every 3,000 miles.
Except the Scion.
End of discussion.
And, I see you type as well as talk. Formidable!
You are wasting a ton of money and oil. With today's high quality
regular oil, unless you have some crappy sludge producing import
engine, every 6mo/6000 miles is all you need. Our fleet of thousands
of cars and trucks ( 90% + domestic) get 6/6000 and it's works just
fine. We have many vehicles run up to 250K miles on that interval and
are still running when auctioned. My area has a couple dozen vehicles
and the last time we had an engine failure was on a 70 Plymouth years
and years ago. That's not to say in the entire fleet we don't
sometimes have a problem, but it's much more likely to be a blown head
gasket then anything else.
It certainly has. This business of getting on usenet and slamming Fram
filters for no good reason has been going on for way way too long. There
is no reliable data or evidence to support these slams but the
perpetrators think they can gang up and bully everybody else into
agreeing with them.
I don't have an opinionated world view. Your the one promoting
opinionated superstitious beliefs. My personal belief is that the
difference between one filter brand and another doesn't amount to hill
of beans as far as the overall effects it has on an engine. Anybody can
use any filter that is designed for the application and change it before
it is saturated with dirt and the chance of having a problem are
practically nil. You can apply the same logic to the filter in a vacuum
cleaner.
There is no evidence that there is any greater risk when using one
brand as compared to another. The way things are nowadays the average
engine will outlast the rest of the car if you just follow the
recommended maintenance schedule.
-jim
filters?
no, just because they're a pathological liar. Keeping what remains of
Usenet useful is dependent on judicious filtering to be able to see the
remaining useful content.
usenet.
that long.
-jim
In clean dry conditions with 2000 mile oil changes, using today's
oils,many engines would live a very long life WITHOUT a filter - and
in many cases longer than with a bad filter (no drainback dry-start
issues)
Heck, my 1949 VW only had a cupshaped flyscreen and IT had something
well over 200,000 MILES on it, in the hot, dusty, and humid
(alternately) southern Zambia conditions.
It had apparently had a valve job, but nothing else. (didn't have
enough power to hurt itself, I always said) before I got it in 1973.
I only but a few thousand miles on it, around Livingstone, up to Choma
and Macha, and one trip down to Chobe Botswanna
