Who was it who mentioned Fram oil filters and dropping oil pressure?
  • Start date
MOST Toyotas today are more reliable than many Chevies - and their
resale value bears that out.
And better than the Mopars and Fords that you buy, according to what
you state below.
That's your opinion and experience I guess.
Mine is I get perfect reliability out my used Chevys.
Which means to me they never worry me or strand me.
If I toss on a $100 alternator once in a while or a $20 water pump
every 60k miles, or a starter, that's small change.
All I've replaced on Chevys gave me fair warning.
The only exception was a bad ignition switch on my '90 Corsica,
which required a tow to a shop.
But even that doesn't change my mind.
Better than paying extra thousands and feeling like a sucker.
There's perception and there's reality. I measure reality in cash.
People are willing to spend serious cash
on used Toyotas and Hondas (Not so much Mazdas, and certainly less for
Nissans), while used GM's, Mopars, and even Fords, do not retain very
much value after 5 years.
That's why I'm not driving Toyotas or Hondas right now. I buy 5 years
old, with 100,000km, for $5000.00 - Have not found a Toyota or Honda
that I can buy for that price in the last 12 years so I drive Mopars
and Fords (and that ONE crappy Poncho- which I bought for
SIgnificantly LESS than $5000 at 4 years of age) and would have been
overpriced at half that.
There's no reason to buy a lemon nowadays unless you're not doing your
homework. I suspect the Pontiac was long ago, or you didn't do your
homework.
--Vic
jim said:
Oh the OPRV was probably working all right. But the after market filter
adapter the guy said he put on the engine was probably covering it up.
(for those who've forgotten posts from weeks past.. I blew up an Orange
Fram when priming (w/electric drill) a rebuilt early chev 283 with an
aftermarket "spin-on adapter")
I'm "the guy". I forget the brand of the adapter, but it was a respected
name brand item. I'd used the same exact ones before with no problem.
After blowing up the Fram filter, I put on a Hastings filter and topped
the oil back up.
The Hastings *didn't* blow up.
Hey this is not my story its just another clowns story. Why didn't you
challenge the guy who told the story early on the thread if you find
fault with it?
I'd say "Jim" is the clown.
I'm still trying to decide if he works for Fram or one of their
distributors; or if he's just an argumentative Fram fanboi.
In my carreer as a motor mechanic, 12 years of it with Toyota, the last 10
of those as service manager from '76 to '86, I can truthfully say the
amount of "repair" work we did was EXTREMELY low. I think in those 10
years we had "mabee" 2 automatic transmission failures, and replaced
bearings in a dozen or so manual transmissions. Had a couple noisy diffs.
Back in 1972 (first stint with Toyota) we had a rash of cracked (corolla
1600cc - 2TC) cyl heads replaced under warranty. The early tercels had a
suspension rust recall that was significant. Electrically they were almost
bullet-proof too. Some high resistance starter circuit problems (woudn't
crank hot) that were easily fixed - and the old rotting brake rotor
problem that every manufacturer was faced with when asbestos pads were
eliminated.
I had a '74 3KC, 1200cc engine Corolla. I had another one in '78, but a
Mustang saw fit to end it's life at 51,000 miles. Then I got a "Trueno",
1980 Corolla coupe with a 1.8. First year model, too. 240,000 miles later
I bought the "Hachiroku" '85 Corolla GTS (Trueno) that I drove until 2001,
and then rarely for three more years. Slowly returning to the Elements in
the back yard, alas getting too rusty to fix.
But I can get one of these down the street for $600...
http://images01.olx.com/ui/1/77/83/13687483_1.jpg
Body is in very good condition, and the 4A-GE will bolt right in, along
with some other parts from the GT-S. Even the wheels will fit.
This could get interesting...
BTW, my '74 Corolla blew a rear end at 14,000 miles, which Toyota replaced
no problem, and then went on to 210,000 miles even though while I was away
at school my father ran it for a few MONTHS without the cap on the oil
fill...
A few years ago someone gave me an '83 Tercel AWD wagon, 5-speed with an
EL gear you could only get to in AWD; I used to plow through the drifts
with it. I repaired the body once, ran it for two winters, and when it
started rusting again I gave it up. Thing was an absoulte tank. Had
210,000 miles on it when I got it, and I only used it in the winter.
One of the absolute best winter cars we ever had was a '72 Corona my Mom
bought new. It didn't even need snow tires. However, the '80 Corolla was
unbearable, and the 85 GT-S was immovable when it snowed. I never drove it
in the winter, anyway.
the oil back up.
If you were really interested in having a strong filter container on
that engine you would have stayed with the one that was designed for and
came with the engine.
Here is the problem I have with the common folklore that some people are
pretending is common knowledge. The folklore got its beginning with
people cutting open filters and analyzing the contents - something
similar to reading tea leaves in a cup. If you look at the big picture
the number of people who share this common set of beliefs about Fram
filters being junk is pretty small compared to the number of engines
that are using Fram oil filters without any incident. That is there are
a large number of people out in the world at large that apparently do
not buy into the so called common knowledge about Fram filters. The
group that does nurture this common folklore is small and the number of
Fram filters that this group uses is even smaller since many of them
claim to have used only one Fram filter in their whole life. Yet this
small group produces a rather astonishingly large number of all the
stories about Fram filters being the bogeyman. Of course the folklore
includes a ready explanation for this. This group is knowledgeable and
all the others are ignorant.
The Fram folklore stories seem to run along lines like this:
I modified the lubricating system on my engine and the filter blew up
I'm sure the fault was due to the Fram bogeyman.
I bought an old beater for $500 that has 250K miles. It has low oil
pressure. This must be the Fram bogeyman.
My engine has low oil pressure. I'm sure it has nothing to do with the
slick 50 i have been putting in it. it must be the Fram bogey man again.
And so on and so on.
I'm sorry but i don't buy that these are stories from knowledgeable
people. IMO these are stories from superstitious people.
-jim
Ths conversation was suppose to be on oil filters and now we are talking
quality of vehicles.
From my 46 years of ownership with automobiles, I have never seen any
problem with any engine from oil filters from any manufacture.
My area does not have to deal with cold temperature starts; we luck if we
even get down to low 30's in the winter.
As far as car quality of cars, I have owned Fords, Toyotas, Pontiac, Chevys,
Mazada, and Dodge. Every vehicle I owned was driven for over 150,000 miles
before I sold it or traded it in except for one Ford that had 3 miles over
70K when I traded it and promised never to own another Ford. That vehicle
had two transmissions replaced under warranty and when it went out with 70K
plus 1 mile and Ford refuse to replace it because it was one mile out of
warranty, I put a new tarnsmission in it and drove it to the Pontiac
dealership and traded it in. I knew people are going to agree with Ford it
was out of warranty but my arguement was the vehicle was repaired twice for
the same problem (once an 29K and once at 55K) and it went out again. There
was an issue with the transmission and they would not acknowledge the
problem. Interesting, 6 months after I got rid of the car, one of the Ford
mechanics told me that Ford issued a service bulletined stating what was
causing premature transmission failures in theses cars.
So my belief is that all make good quality cars and they all make crap at
times. I do believe it is how you maintain your vehicles will determine
how long they last.
My present vehicles are all Dodges and no issues with any of them but they
are all serviced by the dealership my wife works at. They have caught some
potential problems and took corrective action to fix before any major
repairs. By the way, I only let one of the dealers mechanic work on our
vehicles.
SMS said:
What's ironic is that it's probably the same people throwing away money by
doing 3K oil changes that are also buying the worst quality filters.
I use premium filters, not Fram, and change oil at 3500 miles. I dont
consider
it throwing away money, and you have no proof that it IS...just an opinion.
consider
LOL, YOU'RE the one changing the oil far more often than every expert
mechanic, and every vehicle manufacturer says is necessary for maximum
engine life. It's you that has to provide the proof that there's an
advantage, not everyone else that has to disprove it.
jim said:
It seems to take you a long time to google for quotations that turns
out
to contradict the point you were previously making. Before you were
quoting the results of single pass tests. Now you quote the
procedure
for a different test. What is it you think these quotations
contribute
to your position?
I was jsut trying to help you out. You made some really dramatic
claims for Fram filters (like "tests have shown they [Fram] do remove
smaller particles than wix or purolator." I thought if I posted what
Honewell actually claims and what the test involves, you might quit
making claims that exceed what the manufacturer claims.
Yes it is exactly and precisely the same . At least it is if you are
using the same basic definition of the words that automotive
engineers
use. If you have your own definitions for words then you should give
them.
I don't see where you have explained what exactly "remove a lot of
very
small, non-harmful particles" means. But it is Crystal clear that
previously you were claiming Frams are bad because they are too
aggressive at removing the smallest particles. Now you seem to be
desperately digging for data on the web to refute that claim.
Again, you are making up stuff and trying to twist what I said. I
never said Frams are too agressive at removing small paricles. You are
taking stuff out of context and trying to interpert it to imply I said
things that I never said. Go back and read the original statement in
context. It was a broad general statement, that even you agree is
true - removing very small "NON-HARMFUL" particles is not a good
thing., I never said Fram filters did this (in fact I am sure they
don't). I certainly never said anything like - "Frams are bad because
they are too aggressive at removing the smallest particles." It seem
you arguement technique is to deliberately misinterpert what someone
saids and then attack a your twisted version of the position, while
pretending not to notice what they actually said.
For reference, here are the original paragraphs in context (forgive me
for reposting something) -
***Begin Repost***
[You said]
The fact is it has been scientifically proven that Fram filters
do a better job than Wix for removing the smallest particles
from the oil.
That was not determined by cutting filters open but by doing tests
on the oil after many miles of service. And the effects of not
filtering the finest particles takes many years and many miles to
show up. The look of the filter may be important to you, but
many taxi and delivery services use fram filters because they
are more interested in the results than what the filter looks like
on the inside.
[I previously said]
[You said:]
Because tests have shown they do remove smaller particles
than wix or purolator. That can be a good thing or a bad
thing. If you have an old beater that is loaded up with an
accumulation of those fines plus a worn out oil pump from
many years of pumping those small particles putting a
Fram filter on the engine can lead to trouble.
[I said]
Who's tests have shown that? I've read everything FRAM calims, and
they don't claim to be better than WIX. I can't find numbers for
Motorcraft, so I can't be sure that they are better than FRM filters,
but I'll bet they are.
And remember, removing particles below a certain size is not
important. What is important is removing as many as possible of
particles that can damage your engine. If you remove a lot of very
small, non-harmful particles, all you are doing is pluggin up the
filter sooner and reducing flow through the filter element, resulting
in the filter going into bypass mode, and in this case, you aren't
filtering anything.
Of course with a FRAM, this might not matter, becasue the crappy end
caps often come loose.
****End Repost****
You are now claiming that I implied Fram filter could lead to problems
becasue they filter too fine particles. This was actually your claim
("If you have an old beater that is loaded up with an accumulation of
those fines plus a worn out oil pump from many years of pumping those
small particles putting a Fram filter on the engine can lead to
trouble").Clearly I never said Fram filter were particlularly good at
removing fine particles. In fact, I repeatedly questioned your
unsupported claims that "tests have shown they [Fram] do remove
smaller particles than wix or purolator." I was sure this was BS then
and I still do. There are no tests that I have seen that show this. My
comments about the dark side of removing very small particles was in
direct response to yourr BS claims about Fram removing smaller
particles than Wix or Purolator. I was not claiming that Fram filters
were bad becasue they removed very small particles, I was responding
to your BS about how Fram could remove very small particles. No filter
manufacturer (not even Fram) would create a filter that removes
particles that were to small to be harmful. This would increase filter
cost for no reason and actually make it less useful.
So your comparison is what WIX filters remove from oil in a test
involving multiple passes to what Fram filters remove in a single
pass?
You think that is a meaningful comparison?
Go back and read what Honeywell actually claims - they are claiming an
efficency based on a multi-pass test, just like Wix. Honeywell is
using the newer ISO 4548-12 multi-pass test, Wix is referencig the
older SAE J1858 multi-pass test. Wix actually provides the Beta Ratio
from the test. Honeywell just quotes one number for 20 micron
particles. For the Extra Guard they claim 95% for particles 20 microns
are greater. As I pointed out, the Beta ratios provided by Wix imply a
96% efficiency at removing particles 20 microns or greater. The two
companies are using different multi-pass test standards, but I think
it is reasonable to assume the results for a given particle size
should be comparable. BTW, Purolator claims the PureOne removes 99.9%
of all particles 20 microns or larger when tested according to ISO
4548-12 (same test Fram is using in claiming 95% efficiency see
http://www.purolatorautofilters.net/products/oil_filters/Pages/pureoneoilfilters.aspx )
.. A PureOne cost with a few cents the same as a Fram ExtraGuard, yet
it includes a silicone anti-drain back valve, is better made (my
opinion) and filters much better (at least if you believe each
companies advertising copy). Tell me again why you prefer Fram
filters.
So is the quality of the filters Fram makes other than the standard
line OK? If someone buys the other Fram filters you see no problem?
Actually I think the more expensive Fram fitlers are a horrible
choice. The Tough Guard uses basically the same construction
techniques as the Extra Guard, but with supposedly better filter
medais (99% efficient at removing particles >20 microns) and a
silicone anti-drain back valve (like the standard Motorcraft filter).
The Xtended Guard is really a weird one - it costs even more, yet it
has a lower filtering efficiency than the Tough Guard (97% for >20
microns). It's main claim to fame for it is the addition of a metal
screen around the media. The High Mileage Fram filter claims to add
some sort of sanke oil to "balance oil PH and maintain viscosity."
They are definitely moving into Slick 50 territory with that one.
If the Extra Guard is so great, why offer all these other choices?
Your the one doing all the googling of SAE tests. You must have
stumbled
across several by now.
I tried, but I cannot find a single one that shows a Fram filter is
better than a Wix or Purolator filter. Can you point me towards one?
It's better than leaving a Fram in place for longer than the auto
makers
recommendations. The assumption you are changing filters at least as
often as the recommended maintenance schedules.
So you think the choice of filter must always be based on some kind
of
superstition belief? I didn't state a criteria for picking Fram. I
simply stated your criteria for avoiding Fram was primarily
superstition. And it is obvious the superstitious beliefs started
after
cutting open a filter.
As far as I can tell the price available to you is the only criteria
you have for selecting a brand that is based on anything real.
Again, you are trying to argue against stuff I never said. Here is
what I beleive (I'll try to be as clear as possible):
Of the "popular natonwide brands" (Motorcraft, Wix, Purolator), I
think Fram filters use the poorest construction techniques. Fram does
not claim to have better filtering efficiencies that filters from
Motorcraft, Wix, or Purolator. They only claim to be better than
unspecified "economy filters." I am not sure which filters these are.
The standard Fram Filters (Extra Guard) are not particularly cheap.
They usually cost around the same as brands that appear to me to be
better made (Motorcraft, Wix, Purolator, and some others). Given that
I feel they are not as well made as some others, and that Fram doesn't
claim the Extra Guard filters have better filtering efficiency than
other brands available on the same shelf in the store (usually
Purolator and Motorcraft), and that Extra Guard filters often cost as
much or more than other filters I like better (Wix, Purolator,
Motorcraft), why would I buy a Fram filter?
Yes there is a gap above the endcap but it never moves into the gap.
How
would it with the oil pressing against it pushing in the opposite
direction?
OK, again, look at the picture and tell me how the Fram relief valve
works. And then tell me why the same forces cannot affect the end
caps.
That description describes a Fram also. The Fram pleats are glued
together at the ends also. But what you just described has nothing
at
all else supporting the pleats. The Fram has the extra cardboard
support
to keep them evenly spaced. So isn't that a better design?
They are not glued together in the manner I was trying to describe.
The Fram pleats are open up to the end cap. They are closed off solely
by the end cap. The other technigue involves bonding the individual
pleats together along the top edge. It gives the top and bottom edges
of the element a sucked in look becasue the pleats are bunched tightly
together at the ends - sort of like an old wodden barrel instead of a
uniform cylinder. The "end caps" are not glued to the filter element
at all, they just act like retainers. The Fram end caps are the
sealing surface.
You mean kinda like this"
"I've seen other filters that use just
a simple retainer (think plastic or paper)
at the top of the filter
element, but these filters
glue the pleates together, "
NO, see above - completely different techniques.
So obviously because you "know" this can't possibly work it is now
perfectly OK to now make up stories about engine failures - Right?
It can work, but it is not as reliable as other methods. I've never
made up any stories about engine failures. QUit trying to dismiss my
comments based on things I have never said. I've seen the filter
element detached at the glue joint, not torn. I understand that the
Fram methods usually woks OK, but I have seen the joint fail as well.
I have never personally had any sort of engine failure related to a
bad oil filter. I am only saying that compared to other fitlers that
are in the same price range, Fram filters use an inferior constrcution
technique. Their technique can work, but, in my opinion, it is more
likely to fail than other techniques. The results of the failure may
be unimportant most of the time, but why would I spend as much or more
for a filter that is at best no better than filters from other
suppliers?
You don't need to describe how these filters are constructed. I have
seen hundreds of paper replacement cartridges with this same design.
I
have seen them when they are new and after they have filtered the
oil
and I didn't need to rip and tear and damage anything to get a look
at
them.
Well there are several engine manufacturer's OEM filters that use
this
design since they are made by Fram. They I'm sure have looked at a
lot
more filter guts than you have and they have the reputation of their
entire manufacturing process at stake. So I find them a just tad
more
credible.
The fact that the thinner paper pleats can collapse and rip away
from
the end cap in many cases is caused by cutting the filter open.
Explain why this would be the case. I have a purpose designed device
for cutting open filters. I always cut them open at the base end. The
element always come out whole. The only filter I've ever cut open with
detached pleats was a Fram filter (although the I am amazed that some
of the Delco filters don't fail as well).
But you
haven't said anything convincing that the end caps themselves move
anywhere at all. The mode of failure you describe was the paper
filter
media collapsing inward and ripping away from the end caps. This
could
happen even is the caps were steel and you have said nothing that
would
indicate the Fram filter media ia any more fragile than anyone
else's.
If the filter media is collapsing towards the center with any brand
of
filter, that should be telling you something about your engine.
I've never had this problem. I've never claimed to have even seen this
happen. In fact, I can't see how it would happen unless you had a
filter that was almost completely plugged. The pressure differential
across the filter media is usually much less than 10 psi (more like
2). Anyperson with a collasped filter core likely used oil that was to
viscous and didn't change the filter for ages. I have heard of people
blowing filter cans open, but this is a whole different problem. The
pressure diffferential accross the filter wasn't the problem, it was
the internal pressure in the oil system (as with a stuck pressure
relief valve). I suppose a blown case might damage the fitler core,
but it might not as well. The pressure inside and outside the filter
core is still limited by the bypass valve. SO as long as the bypass
valve functions properly, the differential force that might crush the
filter element is relatively low.
Sounds like since you endcap theory fell on its face you are
modifying
your position to claiming they don't use enough glue. And I imagine
if
that theory was shot down you would move to a theory that there is
too
much glue and it is using up valuable space that could be used for
filter media and crud.
Which end cap theory is that? I've been consistent in not liking the
Fram construction techniques. The paper end caps are not particualry
rigid. FIlter media retention is dependent on the glue joint from one
non-rigid body to another non rigid body perpendicular to the first.
They only apply a thin bead on both sides of the filter media and the
inside of the central core. Any gaps or misplacement of the bead can
lead to failure of the joint and leakage past the filter media. Most
other filters use metal end caps and the filter media is completely
encapsulated in glue (or potting compond). The Motor craft filter
media (and central core) are potted into the end caps which are filled
with the glue (or whatever you want to call it). There is little
chance that the media and core won't be firmly attached to a
relatively stiff metal end cap (which includes flanges that make them
much more rigid than the paper end cap used by Fram).
I would much prefer to have an engine where there is zero danger of
it
going into by pass mode. That isn't hard to achieve. If you do have
such
a cruddy engine then don't use a Fram I strongly suspect that Fram
would
like to see those engines go to their competitors. But since you
brought
it up what has the bypass got to do with the endcaps moving.
The filter on just about every engine goes into bypass mode at one
time or another. The bypass opens at something like 8 to 16 psi
pressure differential cross the media (varies by application). With
warm oil at an idle, the pressure differential accross the filter
probably never exceeds a few psi. But on a cold morning, when you race
an engine, I'll bet it will and therefore lift the bypass valve.
And you still didn't answer my question about how the Fram bypass
valve works. Saying you don't want it to work is not answering. The
reason I ask you to explain its working is simple. You keep implying
there are no forces which might deform the paper end caps. I suspect
the Fram bypass valve works very poorly. It seems to offer less flow
area than the bypass valves for many other brands. I think it is
possoible this will lead to higher pressure differential across the
element than will be seen by these other brands. Higher forces
pressure differential across the element combined with an inferior
media to endcap bond design has to increase the chances of that bond
failing. Maybe it is still only a minor concern, but again, why pay
the same or more for an inferior design?
No need to google. I'll concede that point. When the outer shell
blows
off, the end cap and everything else inside the can is going to fall
out
on to the ground. But don't you have any curiosity as to what would
cause a can to burst.
No actually the cardboard looks a little thinner. And as far as I
ever
saw everybody made them pretty much the same.
As I said if the center tube hasn't collapsed you can be sure the
end
caps haven't gone anywhere.
Not the ones for the 283. All brands have the inner support tube.
How
they are made probably depends on what the specs are for a
particular
application are.
Nope I still have one and i cut open a used Fram extra gard to
compare
. The modern spin on has thicker cardboard end caps and more glue on
the
ends of the pleats. Other than that and the size there doesn't seem
to
be much difference in design. The filter I have is a hardware store
brand so it may or may not be made by Fram. But IIRC they all pretty
much looked the same on the shelf in a store where you had a choice.
The first picture looks like the stock filter for the 283. The
endcaps
are made of cardboard and what you are calling a metal can is just
glossy paper wrapped around the filter media. The purpose of the
paper
is probably to keep the mechanics greasy fingers off the filter
media.
That paper looks like what you would find in a typical glossy
magazine
with a bunch of holes punched in it.
The other bypass filters in your pictures must be some after market
product for an auxiliary add-on filter. Couldn't tell you what those
filters are made of.
What about the millions of engine applications where the filters do
not
fail as you have imagined they are going to? You're the one
claiming
they are not any good and have a high probability of failure. I
myself
wouldn't have typed a single word about Fram filters if I had not
seen
others typing so much misinformation. It is just plain irksome to
listen
to all these obviously unsupported allegations.
I could have said that. Until i see some believable facts to change
my
mind I will be sticking to my own beliefs - thank you very much.
Not really no. But then I can't recall making a statement about my
filter preference. I have never personally had a problem when I used
a
Fram. I have never met any one else who had a problem and all told
that
represents quite a lot of filters that haven't failed. I never even
thought about it until I started reading some of the obviously bogus
claims by the Fram bashers. The typical Fram basher has used only
one
Fram filter in his whole life (and he usually won't even admit to
buying
that one) and he will tell you about the numerous defects that one
filter exhibited. Well I'm sorry that is just way too implausible
and
improbable to be believed.
Care to point out some of these stories? I Googled Fram failures and I
do see a lot of people unhappy with Fram filters and some stories that
claim engine failure related to Fram filters, but there are not that
many out there. I am not basing my preference for filters other than
Fram on these sorts of stories. I just don't like the way they are
made. You made claims (or at least I thought you made claims) that
Fram filters did a better job of removing stuff from the oil than
other comparable brands. I don't believe this to be true for the
standard Fram filter (the Extra Guard). At best they claim to be about
the same as Wix filters (I am being charitabkle to Fram here). I've
never seen any "official" independent tests that compared the various
filter brands based solely on filtering performance. I have personaly
cut open many different oil filters and see no reason to believe Fram
filters are better than competitive filters from other manufacturers
(like Purolator, Wix, Motorcraft). It is true you cannot devine
filtering efficiency by looking at the media, but I would argue that
media of the same thickness, densisty, and appearance are likely to
have similar filtering performance - particualy since when the
manufactuers claim similar efficiency. Fram does claim greatly
superior efficiency compared to some unnamed "economy filter." I've
never seen them try to compare thier Extra Guard filters to filters
avaialble at similar prices from the other major filter suppliers
(Wix, Purolator, Motorcraft). It is pretty easy to claim you are great
compared to some theoretical bad filter. Maybe Fram should match
claims with Purolator (Purolator claims the PureOne Filter removes
99.9% of particle 20 microns or larger when tested according to ISO
4548-12).
I don't know what your asking?
So if one scenario of filter failing doesn't support your
superstition
you move on to another. Please don't ever pay any attention to all
the
cars that aren't having the problems you imagine they must be
having.
What has superstition got to do with anything? It seem to me you are
the one making faith based decisions. As best I can determine you buy
Fram fitlers becasue you you assume past performance guarantees future
performance and you believe the Fram advertising copy.
Which senario am I moving from / to? I think I have been pretty
consistent in saying I don't like Fram filters becasue of the way they
are made. I've never said I don't like Fram filters becasue they fail
and destroy engines. I have persoanlly seen a Fram filter with the
pleats detached from the end caps, but the engine didn't fail (in fact
it seems to be doing just fine). I don't buy Fram filters because I
think there are better made filters available for the same or even a
lower price. When I was younger I used Fram filters all the time. I've
never had an engine fail. In fact, I've only ever worn one engine
out - a Ford 800 Tractor engine. And, this engine used Fram filters as
long as I can remember. It originally had a cartridge filter, but my
Father converted it to a Fram spin on around 1960. That's all we ever
used on it after that (we used it another 35 years with Fram filters).
BTW - it still ran the day we sold it.
Just for the record, here is my filter preference for the different
vehicles I maintain:
Toyota
1) Toyota OE Japan made filter
2) Wix or Napa Gold
3) Purolator Pure One (at least until they change them now that Bosch
owns Purolator)
4) Toyota aftermarker filter (Thailand made)
5) Mobil 1 (almost same as Bosch)
6) Bosch (it is confusing now since Bosch now owns Purolator - need to
investigate)
7) Fram
Ford
1) Motorcraft (not sure what will happen - Purolator was making them,
but last OE filter was different)
2) Purolator Pure One (at least until they change them now that Bosch
owns Purolator)
3) Wix or Napa Gold (same filter)
4) Mobil 1 (almost same as Bosch)
5) Bosch (it is confusing now since Bosch now owns Purolator - need to
investigate)
6) Fram
Nissan
1) Nissan OE (Japan or China)
owns Purolator)
3) Wix
investigate)
6) Fram
Honda
1) Honda OE - except I can't seem to find them these days, the Honda
aftermarket filters appear to be Fram
owns Purolator)
3) Wix
4) Fram
Mazda
1) Mazda
2) Motorcraft
3) Wix
4) Purolator Pure One
5) Fram
New Holland (farm tractors)
1) New Holland (nothing else)
Kubota (fram tractor)
1) Kubota (nothing else)
I am not particularly rigid on this. Sometimes the local Autozone runs
a special where you get a Mobil 1 Filter and 5 quarts of Mobil 1 for a
low price. When they do this I always take the deal and use the Mobil
1 Filter. And occasioanly I can't get my preferred brand of filter, so
I pick something else. I've even used a Fram on Hondas several times
(heck I believe the Honda dealer sells repainted Frams as Honda
filters). When I am at my farm, I usually go by a local garage and
pick up filters. The garage carries Motorcraft, Delco, and Wix
Fitlers, so I use which ever of those he has for my application (BTW,
the garage owner doesn't use Fram filters wither - if he can avoid
them - I guess he has been reading the Internet stories, well except
he doesn't have an Internet conenction). I am also using Toyota
aftermarket filters on the SO's Toyota. I bought a case of filters
from a distributor thinking I was getting the OE style Toyota filter
(which is a really unique filter) but got the aftermarket ones made in
Thailand instead. I don't like them as well as most other filters
available for the application, but I am not throwing them away becasue
of "like" or "dislike."
In my opinion one of the best filters you can buy is actually an
Amsoil EA Oil Filter (made by Donaldson I think). I am often offended
by Amsoil claims, but the filters are really quite nice, BUT, they are
very pricey and I don't see then being worth it. Likewise Donaldson
and Fleetguard have some very well made oil filters, but they are also
pricey and not worth it in my opinion for my particular usage.
Donaldson makes an especially nice filter for Ford FL820 applications,
but since I do regular oil changes (5000 miles max) I don't think I
need them for my Fords (i did try a couple though). I've never
actually worn a Ford car or truck engine out, and some of them used
Fram filters for years.
If I am going to over spend on filters, it will be on air filters, not
oil filters. Oil filters can only remove what is already in the
engiens. Air filters keep bad stuff out.
Ed
Chevys, Mazada, and Dodge. Every vehicle I owned was driven for over
150,000 miles before I sold it or traded it in except for one Ford that
had 3 miles over 70K when I traded it and promised never to own another
Ford. That vehicle had two transmissions replaced under warranty and when
it went out with 70K plus 1 mile and Ford refuse to replace it because it
was one mile out of warranty
Was this a Fairmont, by any chance?
Of course, when I was a kid we had American vehicles. Dad was a
Nash/Rambler man, so we always had one or the other. When he died Mom
couldn't drive with the truck clutch that was in the Rambler wagon, so she
got a Valiant wagon with a push-button trans. I don't know what happened,
but a couple years later she traded it for a 1964 Chevy Nova with the
straight 6. WHAT A CAR! Last time I saw it I think it had 250,000 miles on
it, and that was in 1974. No rust, and still looked good.
Novas were too expensive and too large by that time, and theat's when we
bought the first new Toyota, a 72 Corona. My stepfather
bought a 1973 Caprice of Crap, and in 1978 they traded both for a Zephyr.
That's the car that had the tranny problems; like you, two trannies. When
they wouldn't replace the second tranny at 72,000 miles, it got traded for
a 1986 Camry. Still have that car, with 85,000 miles on it. My stepfather
had a couple of Toyota truck (after getting rid of a Ford Courier), and
they never went back to American cars again.
BTW, my stepfather fought the Japanese in WWII. He didn't care...
But according to Jim, Fram are not the 'worst quality filters."
Also, many years ago CR did a report on oil filters. Since at that time I
had two new Toyotas, I was pretty pleased when the little sidebar said,
"If you own a Toyota, you're getting the best filter made from the Toyota
dealer."
Bullshit. I'm an expert mechanic and do the same on my own vehicles.
5000Km on Dyno oil, and 6000km on the PT with synthetic.
dealer."
Way back when, Toyota filters were Purolator, in Canada anyway.
you state below.
homework.
--Vic
About 7? years ago, and I KNEW I was not buying "first quality oats".
I knew what killed the original engine, and what engine was put in (I
bought the vehicle for $500 after the engine had been overheated, and
had an AC DELCO crate engine installed. for something like $2600 plus
labour). A year later I had the tranny rebuilt for another $2600. Made
it the most expensive vehicle I have owned since 1996, when that
amount of money (total expendature) bought me a brand new Dodge
RamCharger.
That said, The Ramcharger was possibly the second most troublesome
vehicle I have ever owned, and cost, without a doubt, the most per Km
driven.
Well your not helping me out by quoting advertising.
I didn't make any dramatic claims I said independent studies have shown
that Fram did better on some of the tests that indicated it removed more
of the smaller particles. I didn't say whether that was good or bad.
According to SAE standards they all remove the amount of dirt needed to
keep the engine running. It's been 30 years since I have seen an engine
that was maintained on the manufacturers schedule that has died due to a
lubrication related failure. If you want to worry about extending the
life of a car worry about how to keep the upholstery or the
thing.,
No you have failed to understand what I agreed was true. I agreed that
overloading the oil filter is always a bad thing no matter how it
happens. And i agreed that it may be possible that if person switches
filter brands to one that is more aggressive after many many years of
using one that is not aggressive that could make it more likely to
overload the filter.
The point that you can't seem to wrap your head around is that brand
new cars do not come with an accumulation of small particles in the
engine crankcase. Whether or not you believe fine particles are harmful
if the filter is not removing them from the oil then over many years and
miles some of those those fine particles will accumulate. That is why
when you wipe your finger on the inside of some old engines your finger
looks like it is covered with black paint.
Old cars sometimes do come with an accumulation of fine particles and
that certainly makes it more likely that a filter that is more
aggressive will become overloaded.
Well that's what it sounded like. You made your statement in direct
response to the claim that studies have shown Fram to be more aggressive
at removing the smallest particles. You then went on to quote pages of
advertising copy that you seem to think was either proving or refuting
the point depending on which way the wind was blowing at the time.
It seem
I quoted what you actually said. You quoted what you actually said. If
what you actually said was meaningless and completely irrelevant to the
discussion (as you seem to be claiming now) why did you say it?
***Begin Repost***
[You said]
from the oil.
on the inside.
[I previously said]
[You said:]
[I said]
filtering anything.
****End Repost****
You don't seem to get it - there is nothing particularly useful in
regurgitating advertising copy. I pay no attention to what Fram says
about Fram filters or what Wix says about Wix filters. When you say you
are quoting somebody's advertising I usually skip to the next paragraph.
i can see no point in trying to compare ad copy. Its even dumber than
cutting filters open.
That is what you claimed. At least that was your direct response to the
claim that independent studies have shown they do remove the finest
particles.
trouble"). Clearly I never said Fram filter were particlularly good at
are doing is pluggin up the filter sooner
element, resulting in the filter going into
filtering anything.
So what are you saying
1) this statement was complete fiction it never happens to any filter.
2) This is what happens to other filters never to Fram filters
3) This is what happens to Fram filters.
and I still do.
It's not my BS several studies have shown that Fram is better at
removing smaller particles then some of the others. IMO It doesn't make
much difference. Which brand removes the smallest particles is a moot
point - its not worth even knowing. It's been 30 years since I have seen
an engine that was maintained properly that had a lubrication related
problem that led to its demise. Cars that have the prescribed
maintenance die from just about anything else nowadays and it doesn't
make a bit of difference if you used a fram or purolator or wix or
whatever. If something else sends the car to the crusher anyway why
worry about it?
But if you are going to worry about it look at the studies that the
truck engine manufacturers have done. The have good evidence that
removing particles down to 2 microns will make a significant difference
in ring and bearing wear.
Nope sorry I'm ot even in the least interested.
filters.
Tell me why you are no longer beating your wife.
Well if Cadillacs are so great why offer a chevy. the cheapest filter
you can find will do an adequate job.
Somebody pointed to consumer reports test. I would have to believe that
it made a difference to be motivated to do your work for you.
Whether any of that is true or not makes no real difference. Even if
"Fram filters use the poorest construction techniques blah blah blah"
were true. It wouldn't make any difference. There is practically zero
chance that using Fram filters for the entire life of an engine will
shorten the life of the engine. So all this dissecting of filter parts
and analyzing advertizing c claims is a massive waste of time.
caps.
You tell me how the relief valve works. The relief valve itself does not
contact the cardboard end caps so I don't get what you are getting at.
The endcaps are not in the same place so obviously they don't see the
same forces. If you replace the relief valve with cardboard that
cardboard would be affected by pressure.
And all of this is absurd anyway since if you have such a cruddy engine
that you are threatening to blow the by pass valve the brand of filter
is the least of your worries.
by the end cap.
the glue not only attaches the end cap it glues the pleats together.
sealing surface.
So?
Is that like a distinction without a difference?
I told you I have seen a lot of filters with that construction both
before and after they were used. It looks like it works very well to me.
Based on your superstition.
I've never
I agree you have said you never had an engine failure and i do find that
to be refreshingly honest. I didn't mean to imply you had made up
anything. What I meant is the vast number of Fram basher stories I
believe are made up. The think just like you do that "this cant possibly
work" and so they feel compelled to create a story as a cautionary tale
to others.
suppliers?
I have seen a lot of filter elements and none have torn. but i can
imagine if they are overloaded the paper pleats will collapse inward and
tear from the ends. But that would happen if the were glued to metal
also.
So now your introducing the idea that fram uses more fragile paper for
the pleats. All the filters i have seen the glue and endcaps are atleast
10 times stronger than the paper.
Well it does happen i've seen pictures. For one thing not all filters
have the bypass valve. Some applications have the valve in the engine.
So one way it happens is using the wrong filter.
Actually they aren't any more rigid.
I know the filter on the car i now drive never goes into by pass mode.
It doesn't have one. And what do you think the pressure regulator does?
It's my answer.
<The
I'm doubt the area of the valve opening is less than the oil galley
leaving the filter. Do you seriously think all these imagined failures
are really going to happen. Do you believe that all the quality control
departments that have look at these filters are so much dumber than you
are? Any large retail chain that is selling the filters or any lube
service center chain is going to have gone over all this much more
thoroughly than you have, because they aren't interested in antagonizing
customers.
4548-12).
I claimed that both your study of the advertisements and the study of
filter guts are irrelevant. Putting a filter that is better than or
worse than Fram on your car is not going to make a difference. All the
people that i have seen that claim engine damage from fram are blowing
smoke. They already had or would have had engine damage anyway and that
is assuming you believe the story.
It is superstition when you think taking some action will have an effect
and it won't .
OK you are a strange person then. Why do care if they don't do any harm.
I must admit you have been the only Fram basher that comes across as
being honest. I personally never thought much about filter brands until
i observed the hysteria of others. As far as i can tell the way the
manufacturers have got the bases covered it makes as much sense as
worrying about the brand of gasoline you use. Sure there are
differences. but it isn't really worth the effort to decipher them.
I have personlly seen a Fram filter with the
It likely didn't even allow much oil to go unfiltered. The force of the
oil would tend to close in on any tears. It is the opposite of the
forces of a balloon that pops.
OK I'm not going to go through all that. It's like reading your choices
for brands of toilet paper. Its not like you are going to use these
things over and over again. They don't need to be made like a swiss
watch.
-jim
Show me where there was *any* significant change in the small-block
Chevy V8 oiling system when GM changed the block casting to use spin-on
filters. That Fram should not have blown up.
If I remember correctly, GM used a similar adapter for a few months to
use up the "non spin-on" block still in the parts pipeline.
RamCharger.
driven.
Wonder if the overheating engine also overheated the trans.
I've avoided cars that had any big trouble in their history - that I
could tell anyway.
Especially if it's in an ad that says "Runs. Needs a little work.
Many extra parts tossed in."
But trannies can go from "fine" to broke real quick, with no warning,
so that's always been my main worry when I buy a used car.
Been lucky so far with my Chevys. Only the '76 Caprice failed, where
I had to drive it to a shop in low gear. Cost a few hundred to fix.
But it was "acting up" when I gave the car away a few years after
that.
Daughter's got a 2002 Mitsu Eclipse V6. Wouldn't settle for my
$2500-3500 gift first car I offered all my kids when they got their
driver's license.
With that they got free maintenance less parts, and basically just
paid their own liability insurance.
She had to have the Mitsu. We fought with her for a while but gave
up, and I kicked in $3000 toward the car. She paid the rest of the
$15k - took her about 4 years to get it paid off.
Plus she paid about another $3k in maintenance, including a trans
rebuild and balancer. And comprehensive insurance of course.
Never stranded her, I'll say that, and it still looks new.
Since she's been happy with the car, I'd have to say it all worked out
well. Not my style at all, but different strokes.
A crate engine is sometimes a good option. One of my sons bought
a used late '80's Chevy Caprice estate wagon with the factory Old's
307.
He got it cheap, about $3000, but didn't realize it was a smoker.
Cat was eating the smoke. Very clean otherwise. Big yacht.
Coming home from college one weekend it was dying on him, and a savvy
mech punched some holes in the cat so he could get home.
My mech - does primarily GM work - had seen these 307's before.
A batch from the factory with soft cylinder walls. Gone in 60-80k
miles, and this one was right at 80k.
If you sat in this car you wouldn't want to throw it away, so my mech
said he could put a 60k GM warranteed 307 crate engine in it for
$3500. Said the soft wall problem was gone.
Think it was $2400 for the engine. We had him do it.
Sometimes it makes sense, and since the car was otherwise almost
perfect, we figured this was one of those times.
Very nice. About 6 months later my son was out of college and
teaching elementary school in the city - Chicago.
Came out of school one day, and the car was gone. Never recovered.
Of course it wasn't insured for theft.
--Vic
No a Taurus
My bother had 2. AXOD trannies.
Had to have both fixed.
Some plastic part cracking if I recall correctly.
Big money for little plastic.
He still loved the cars though.
Go figure.
--Vic
Go figure.
--Vic
AXOD. The tranny that was so bad they had to rename it. If your
brother likes the Taurus, he should look for one with the AX4N tranny.
Much better than the AX4S (which is the old AXOD).
Paulwidd
