Subaru Tranny again...
  • Thread starter Hachiroku $B%O%A%m%/(B
  • Start date
HLS said:
Sometimes Autozone will have tools, perhaps torque wrenches included,
which they
will lend with a deposit, and reimburse when you bring it back. Maybe
this would
be a way to proceed.
The basic old fashioned bar types sell in the $20.00 range....
Mike
86/00 CJ7 Laredo, 33x9.5 BFG Muds, 'glass nose to tail in '00
'New' frame in the works for '08. Some Canadian Bush Trip and Build
Photos: http://mikeromainjeeptrips.shutterfly.com
Mike
86/00 CJ7 Laredo, 33x9.5 BFG Muds, 'glass nose to tail in '00 'New' frame
in the works for '08. Some Canadian Bush Trip and Build Photos:
It has to be small. Unfortunately, the picture in the link looks like
there's plenty of room..
Pictures can be deceiving...
When you say "jumping" or "jolting" do you mean like a harsh shift? Harsh
shifts can be caused by bad accumulators, which are usually under the
transmission pan.
This is worse than a harsh shift. It slams from 1-2.
The repair manual suggested the band adjustment, and it seems to have
worked...for the most part.
What is your story HLS same as JoeSpareBedroom same as (e-mail address removed)?
Why do you need to change names to put someone down? If it bothers you
so much, do not read the newsgroup.
Are u a mechanic without work?
While you're checking things out, check the throttle cable adjustment.
Why do you need to change names to put someone down? If it bothers you so
I didnt change names nor did I particularly put this guy down. You
apparently
got your panties in a knot for something somebody else posted.
There is a very small one, quarter inch drive, bar type that has commonly
been used
to adjust auto trannies where space is limited. It is not very expensive,
but, again,
you may be able to borrow it from an Autozone or similar. Some of those
read in
inch pounds rather than footpounds, but assuming it has adequate range, you
can
make the conversion mathematically.
Indeed, pictures can be deceiving, and so can procedures in some of the
manuals
that are available.
Question for you... my '99 Outback sometmes slams fairly hard from 1 to 2,
when cold and under no load. It's fine warm, and it's fine when I push the
accel hard. Or, I just idle the cold starts at about 1200 rpm and it shifts
right through.
Also, when coming to a stop, if I don't *completely* stop, when I accel the
car seems to slip into 2 kinda wierd. I can't describe it well.
Does that sound like what you had that prompted you to tighten the band??
Ray O, I'm curious about your opinion, too.
-John O
range....
been used
but, again,
read in
you can
216 in-lbs...
manuals
that are available.
This was the Suby factory manual.
shifts right through.
the car seems to slip into 2 kinda wierd. I can't describe it well.
-John O
That's exactly it!
That's exactly it!
Woah, that's good. :) How can I get a copy of that page or section of the
manual? I'd like to take it to my favorite tranny guy and have them do the
work...this problem has been making me crazy for a long time.
-John O
-John O
I got it from Autozone. I looked to see if they covered '99 model year,
but it stops at '96, and it's the same page...
go to Autozone.com and click the menu item "Repair Info".
I have a '97 Legacy L wagon, but it's buried in the snow right now or I'd
have a look...
That seemed OK.
I'd have to drive it before making any more guesses. Based on what John O
posted, I'm beginning to wonder if this is a "normal" characteristic of the
transmission, or if there is a good fix, then the dealer should know.
the transmission, or if there is a good fix, then the dealer should know.
I've discussed these symptoms several times here, and this is the first time
I've heard someone else having the issue. I suspect my car wasn't driven
easy in its young life. :)
-John O
time I've heard someone else having the issue. I suspect my car wasn't
driven easy in its young life. :)
-John O
er...mine's 19 years old!!!
