Why flush brake system?
Dmitriy said:
it does not dissolve paint. I believe that the fact that they are no
hydroscopic (don't absorb water) makes them even worse, because instead
s/hydro/hygro/
Colorants are used in antifreeze fluids helps differentiate the
chemistry in them. http://en.wikipedia.org/wiki/Antifreeze_(coolant)
Yes, you can go by color.
The Subaru owners manual indicates the use of Glycol based antifreeze,
50/50 with soft water. There are no other indications in the engine
compartment.
All 3 types of antifreeze fluids, produced by Valvoline under the Zerex
brand, with or without silicates and phosphates are glycol based. One
is green, a second one is orange (OAT technology) and the other one is
clear (HOAT technology).
Since my car came with the green antifreeze from the factory, I will
continue to use the Zerex I mentioned in my initial post, the same used
by Nissan.
AS said:
http://www.cars101.com/recalls.html Scroll down to 4/2005 to see the
Subaru recommended coolant to use.
OK - I'm sorry but I found the typo there hysterical;aluminum radiators and engines and is the only type that should be
used.<<<<<
I feel certain it should be non-aMiNe but since Subaru is Japanese........
Lol, that is funny
used.<<<<<
AMARIAL
