I read the link Hachi and I believe you would get a better result in
removing the pan, and visually making sure that the band is barely
dragging on the drum. That 1/4 turn either way statement can be the
difference sometimes.
Tomorrow is supposed to be nice. I think I'll have a look...
I know it's a bit of a pain to remove the pan but I'm almost certain that
you will be able to see a part, if not most of the band.
Actually, on this car it's right out in the open. I'll have to see if I
can get a gasket first. Some parts are plentiful, and others...
Of course, there's alway FIPG!!! Worked on the Supra just fine.
While on your back and the car in neutral, use your foot to rotate the
drive wheel tire. You can see and feel the adjustment as you move the
adjuster screw. I've done this lots of times, but not on a Subaru.
There's 4 of them!!! Actually, it's selectable, but in order to get there,
it has to go up on ramps.
When it just barely drags is the best adjustment. You can also check out
the contents of the pan and the band itself for wear and the band servo
operation as well.
It sounds like you almost have it fixed.
Thanks! I didn't understand how this really worked, but I see (er,
understand) now! Kind of like the drag belt on a machine tool. Knowing how
something works sure makes it easier. I'm lucky, I have a vivid
imagination and can visualize very well. Now I have an idea what I'm
looking for.
It may be I tightened it so much that it catches somewhere and when the
trans goes back to first it frees it and 'realigns' it to where it's
supposed to be. If I get done early tomorrow, I'll have a look.
This car only really gets used in snow and for trips to the grocery store.
Once the snow stops for good, the plate comes off and goes on the Supra,
so I'll have all summer. But thanks again!
