Smart voltage regulator (NOT) = flat battery
Gilbert said:
I am in UK, so quite possibly the US market is different. Do you have
charges based on CO2 emissions ? Are you using daytime driving lights,
or aircon frequently ?
When I talked to Subaru UK they were quite open about it, in fact I
only had to say I was monitoring the battery voltage and they went on
to describe exactly what I was seeing, and the things they had tried
while trying to fix it.
Gilbert
Interesting. Perhaps posting this at www.ulimatesubaru.org and
www.nasioc.com and asking other UK/EU owners for thier experiences in
this line would be helpful. WE do have DRLs but I know of no seperate
environmental controls/taxes involving CO2. Maybe someone else here has
more specific knowledge or another Brit will chime in.
Carl said:
I have yet to experience a dead battery (due to my own negilgence OR the
'smart voltage regulatoer' issue you mention) in my '06 WRX. If the
system was incapable of keeping the battery charged, shouldn;t I have
had a dead battery several times by now?
I'm in the US - are you? Could this be specific to another market?
Hmmmm,
Really? 3 Subaru cars in my family all later than '06 don't have that
problem. Driving with lights on? We have DRL. Fan on? most of time it's
on by default. Lemme see, typical alternator is 3 phase rull wave
rectified and it's output is controlled by field coil current supplied
by imbedded regulator. If yoy measure voltage going to F terminal of
alternator, you'll see whether it is charging or not and how hard it is
charging. As simple as that.
Tony Hwang said:
Hmmmm,
Sorry, the field current is definitely controlled by the ECU since 04.
Monitoring the field current is an indication of the current being
delivered by the alternator, yes, but not an indication of battery
charging current. The voltage across the battery terminals shows this.
I posted one reply at the top (sorry) - here it is again:
I just talked to the Subaru importers, and they know all about this
problem, including having looked for ways of fixing it without
modifying the ECU software. They can offer no solution other than
driving with the fan or lights on all the time. Apparently it affects
all models since 2004, and is due to trying to get the best results
from carbon emission tests by keeping the generator off-load.
Gilbert
Something doesn't pass the "sniff test" here. Even the inafamous old
positive earth Lucas systems weren't any more bass-ackward than that
idea... dunno how the rest of the world runs their domestic market
alternators, but I'd be hard pressed to think of one, domestic or
imported, we have in the US today that doesn't have an integral voltage
regulator. Now, I'd understand the ECU monitoring output voltage so it
has a base line for comparison when it receives its various signals from
this sensor and that, but using the ECU to do the job of the voltage
regulator makes zero sense to me at this moment. Maybe I'm missing
something important?
IF the alternator IS putting out adequate current and voltage, but
you're not getting what's required at the battery, WHERE is the loss?
That's the question I'd be asking myself if it were my car.
Rick Courtright said:
Subaru tell me the alternator is taken off-line a.s.a.p so that it
presents no load to the engine during the emissions test, thereby
getting a better score. They say there is no voltage regulator inside
the alternator because the ECU controls the field current.
They also tell me that turning on the blower to its lowest setting is
programmed to restore normal generator action. I already proved this
myself, and driving lights will do it also.
Don't forget this is an 05 car in pristine condition, and it passes
the Subaru electronic test equipment run with flying colours.
Bottom line is if you have an 04 or later car, and rarely use the fan
or the lights, you end up with a flat battery - believe me, I know.
Gilbert.
Gilbert.
Call up the Subaru parts catalog for your vehicle (at the dealer or
online) and under "Alternator" you'll see a reference for a
voltage regulator. So "they" are mistaken.
Gilbert
You are full of it. You don't even know what you are talking about.
Amount of field current controls the output of alternator. It's closed
loop servo kinda circuit if you see this electro mechanical device as a
electrical simulation. Read your post, ---field current is an indication
of the current deliverd by the alternator---- What does that suppose to
mean? Do you know what field coil does? Do you know what stator windings
do? I think your Subie dealer is full of it too. I live in Foothills in
Western Canada. If charging system does not perform well we can even
start our cars in the morning with dead battery with slush formed
inside. Poential difference(voltage) makes the current flow. Ever looked
into dynamic parameters when alternator is under load and charging at
the same time. Battery voltage sensing line, F terminal, lternator
output terminal, temerature compensation status, etc. with proper
instrument.
Rick said:
You mention Lucas? That POS! Their wanna be alternator which needed
polarization when alternator is replaced like old generator. What
wonderful design it was. I had to redo their regulator to correct that
BIG design fault. It took me one week end to figure that our for my
neighbor who lost charging current after replacing dead alternator.
Doesn't Lucas mean knight of darkness something like that?, LOL!
Gilbert.
Hmmm,
You and your deler both are full of it? What are you smoking?
Sorry for top posting.
Instead of insulting Gilbert, do as I did yesterday and google "ecu control
field current alternator" or similar.
The ECU does indeed control the field current on many alternators these
days. The idea is to effectively turn the alternator "off" or control it to
only produce the current actually needed, apparently by applying square wave
pulses of varying width as field current. It will turn the field off at
full throttle to lessen the load on the engine, for example, when you have
drive by wire throttle. That started in 2004 on Legacies, dunno about the
rest of the line.
The ECU gets its electrical load info from the body control modules,
electronic blocks that react to switch settings on the dash, steering wheel,
climate control and the RFID keyless entry system. My Legacy has several of
these modules up behind the dash, and you have to add a couple more if you
want memory on your power seats and remote start. Amazingly, Subaru expects
you to hold these extra things in place with plastic ties around the
steering column, and the wiring makes my head ache. Got the .pdf for
installing the remote start from subarugenuineparts online, and decided I
can brave the snow instead!
The voltage regulator itself is of course still in the circuit to control
the voltage produced after the change from 3 phase AC to DC at the current
output prescribed by the ECU.
What Gilbert has discovered in his particular car is that unless there is a
minimal load at all times, like the fan, or here in Canada DRLs, the system
goes into some kind of funk mode and allows the battery to go flat. I guess
the solution in his case is to always run a load. I assume something else
is wrong, maybe with his ECU and how it interfaces with the alternator,
because one would hope that Subaru would have covered the scenario where
there is no electrical load beyond the ignition system. But maybe not.
The dealer should know more, but we have all run unto dumb dealers.
Bruce Armstrong
Thanks Bruce, much appreciated.
Gilbert.
rest of the line.
Bruce Armstrong
Tony Hwang said:
instrument.
Ever got out of your armchair and put a digital voltemeter across the
battery ? What do you see ? 14.5v ? 12.5v ? Do you know what these two
voltages mean ? Can you even turn your drls off ? Why would Subaru
admit to this problem if it didn't exist ?
Gilbert
So what you're saying is the car runs off battery power at times,
alternator power at others?
The fact somebody does something a particular way doesn't automatically
make it a good idea, and, sadly, it's my opinion Subaru HAS bought into
a few "less than perfect" ideas in the past. If I understand what you're
describing, I'd like to meet the engineer who came up with this. He
should be hung by the family jewels for such a thing...
I frequently end up with a flat battery in my Forester05, despite the
garage test rig reporting that the alternator and battery are in
perfect condition.
What am I doing wrong ? I am driving without the heater fan or
sidelights on. If you run the battery low by parking with the lights
on (say), there is no way the battery will ever recover unless you
drive with the fan on. (I am not joking). Short journeys or long.
Charging lead-acid batteries is not rocket science, all you do is put
14.6v across the terminals until the charge current shows it to be
fully charged, then maintain a 14.2v trickle charge. Try plugging a
voltmeter into your cigar lighter socket and watch what happens on
your lovely Subaru, then compare it to any other make.
I used a battery maintainer on a previous vehicle rather than disconnecting the battery when it sat. I modified the harbor freight unit to a cigarette lighter plug and was successful for years!
