Piston Slap
Vincent said:
never mind Voja read your other post. I also have trouble with Rt front
bearing and burnng smell at idle. I did see the wet axle; the dealer
said it was spill from when they changed the diff oil aout 5K earlier. I
didn't believe them. I will recomplain.
Thanks for your posts
Vincent
PS.I don't think I have the clunk on reverse!
BTW my gas mileage is about 24 mpg on highway. What do you get?? I would
like for it to be higher. I have tire pressures at 42psi and I do
feather the gas pedal. I think the piston slap might be setting off the
knock sensor.
Drop your tire pressure! Not only are you going to wear them out
prematurely, but your ride and grip are suffering as well.
hroberts65616
