Engine runs rough after fuel filling
Srh
09 outback xt,
The last 2 times I have filled up with fuel, engine has rough idle, stalls couple of times.
No check engine light logged.
Any ideas
09 outback xt,
Any ideas
is it when you first try to start it after filling? sounds like a plugged evap canister. they can clog naturally or can get filled with fuel if you keep trying to fill it after the pump clicks off the first time. either replace or pull the hose off the back of the canister just to test to see if thats the issue
monophoto
