bulb exploded in the lamp
A
AndyL
Hi,
Stupid situation :) I have just replaced a bulb in the headlight and
the new one just exploded a few days later.
How can I get rid of those cracked glass, or should I just ignore it?
Any insight?
Thx in advance, A.
AndyL said:
Hi,
Any insight?
Thx in advance, A.
Hmmm...maybe you could rig some kinda vacuum hose attacment to get near
the socket hole? I dunno.
Remove the bulb housing and shake out the pieces.
If you can't figure out how to pull the housing,
you'r probably better off to just leave the
pieces in there.
This is probably a halogen headlamp. The bulb
shattered from something (anything) that
contaminated the surface and caused unequal
expansion when it heated up. When you replace
it, dip the new bulb in rubbing alcohol, dry it
with a clean paper towel, and insert it without
touching the glass bulb with anything (including
your "clean" fingers).
todd
