Alternator bad? Voltage regulator maybe?
VanguardLH said:
AS wrote:
Yeah, I figured that after thinking about it. The current would go out
from the "+" battery post so the red probe on the DVM on there would've
been backwards to the electron flow.
The only device that I know of that would've been on was the clock in
the radio. No lights, including dome lights, were on. The key was not
in the ignition switch so it wasn't even partially turned to enable some
of those circuits.
I figured if a diode in the rectifier were shorted then that might be
the cause of the drain through it. I found a basic schematic at:
http://www.alternatorparts.com/understanding_alternators.htm
If a diode were shorted, wouldn't that mean that there would be current
flowing through it (back to ground)? I always thought a diode would
blow open due to the heat of the leakage current but then these are
high-current diodes and the leakage current is only half an ampere.
The reason the amp draw may be a little high is because of the keep alive
memory in the radio and computer. Here's how to get around that. Hook up
your amp probe as before between the +post and +cable. Now take a jumper
wire and place it between the +post and +cable. Leave it there for at least
15 seconds (some take up to a minute). At this point your amp probe will
read zero. Once you remove the jumper wire the probe should read much lower
than in your initial test.
All that is moot though as I agree with JohninKY's original post, you have a
bad diode since it's only charging 12.5 volts. BTW... that shop that says
they can't jump the car, then test the alt is suspect. It sounds like they
have an idiot proof tester of some sort and only have idiots to test with.
NAPA sells a very good reman alt with a lifetime warranty. Be sure to ask
for their premium line as they also have a cheaper line with a 3 year
warranty. They also sell a new one for many applications for not too much
more.
least 15 seconds (some take up to a minute). At this point your amp probe
will read zero. Once you remove the jumper wire the probe should read much
lower than in your initial test.
a bad diode since it's only charging 12.5 volts. BTW... that shop that
says they can't jump the car, then test the alt is suspect. It sounds like
they have an idiot proof tester of some sort and only have idiots to test
with. ;-)
more.
PS I just reread your first post. That $118 alt from Pep boys is a great
price for a lifetime warranty! I once bought a $22 alt for a Chevy from
AutoZone. I asked if they had anything of better quality. He said it had a
Lifetime Warranty so I bought it. Darn thing lasted 8 years!
Each of the stores that I went to (after checking the warranty and
price) is selling a rebuilt for $118 to $129 and each has a lifetime
warranty (the $129 unit include roadside assistance to get a jump if the
battery is bad or, in this last case, the alternator won't charge the
battery so the battery is dead and I need a jump to start the car;
didn't get any details on how long that plan lasts). As I recall,
Napa's rebuilt ran around $179 for standard quality, $224 for premium,
and $290 new. This is for an old 92 Subie Legacy that gets maybe 7K
miles on it per year.
I figure if it has a lifetime warranty (for the original car in which it
gets installed) then I can pop in another if it fails. PepBoys has been
around long enough that they'll probably still be around for years from
now. O'Reilly has been around for maybe a couple decades (but when
through name changes). There are some things I won't buy from either,
like brake calipers or wheel bearing, but a lifetime alternator is okay.
Replacing the alternator is not much more difficult than taking out the
battery. Making sure I don't overtighten the belt is the only hazard.
Presumably the half ampere was flowing through the DVM (to measure it at
that rate) was for the clock/radio but I don't know if I left it
connected long enough to setup the clock/radio. I do know what you're
talking about because I had to replace the clock/radio (twice because
the salvaged unit failed but I removed its face to put on another
salvaged unit whose display was faded and had an iffy press button). I
can try what you suggest to see if the current draw drops after, say, a
minute of shorting the battery "+" to cable.
The idea is to also measure the surge current while or after starting.
Although the battery itself passed their automatic tester (first a
handheld one and then in a load tester), they said one of the tests is
during startup. So, yeah, it might be an idiot tester but it's free at
the stores. A more complicated tester involving human cognition would
cost money. The one store said that the alternator can be tested in the
car. The others want me to yank it out so it can be mounted on their
tester (so its belt runs the alternator). While the alternator isn't
that tough to remove (and put back in), I'd rather not do it if not
necessary, plus an in-car test might find a different problem, like a
short in the harness, a short in a dash guage, or whatever.
I'm sure that whatever tester is used at whichever car part store would
all qualify as an idiot tester: follow hookup procedure, press a button,
and wait for a good/bad status. An idiot tester that tests with the
alternator in the car just makes it simpler for me to do the test.
You're making this more complicated than it is. Shorts cause fuses and
fusable links to burn out, not drag the voltage output down. You've already
determined the alt can't put out more than 12.5 volts even though your
battery voltage was well below that. It should have been putting out 13.8v,
if not more on a dead battery.
If you had a problem with your harness or dash gauge not energizing the
alt, or the alt voltage not getting to the battery, the battery voltage
would have read well below 12 volts, not 12.5v. 12.5v is sort of a magic
number. It shows the alt is trying but one of the diodes is burned out.
Testing it for amperage output like the shops want to do, whether on car or
on the bench tester, or testing for starter draw while cranking, isn't going
to show a different result. You really need another alt.
Shorts cause fuses and fusable links to burn out, not drag the voltage
output down.
Let me rephrase that: Shorts cause fuses and fusable links to burn out, not
drag the voltage output down - for more than a few seconds anyway.
already determined the alt can't put out more than 12.5 volts even though
your battery voltage was well below that. It should have been putting out
13.8v, if not more on a dead battery.
or on the bench tester, or testing for starter draw while cranking, isn't
going to show a different result. You really need another alt.
Dontcha hate it when they never come back to tell you you were right, and
thanks for the help. I know I do. </talking to myself>
just wantja to know..I feel your pain.
I haven't had the time to take in the car. As I said, it usually just
sits in the carport. Since last November, I've probably put around a
hundred miles on it. Also, I was going to have my buddy come along in
case there was a problem with the car on the way to or back from the car
shop but he didn't call last weekend, I couldn't reach him, and he
called on Thursday to say he'd stop by to drop off his trailer (for yard
waste removal) but had to leave to prepare for his son's cub scout trip
that he was leaving on. A family member kept disappearing when they
said that they would help. I'd be pissed with both people if it weren't
that this is still a low priority repair. I really only have the
weekends to get at this problem but have gotten disappointed the last 2
weekends with promises of help but didn't get any.
I put the DVM from the "+" battery post to the cable and saw no amperes
this time. Was a bit surprised that there was no current flow but then
found out the 2A slowblow fuse had blown. So I'll disconnect and
recharge the battery and just remove the alternator to get a new one.
Everything points at the alternator so I'll just yank it out and get
another one (with a lifetime warranty this time).
Got a new alternator. Didn't bother driving in the car or removing the
old one to have it tested. Nothing else looked like the culprit than
the alternator. Used my newer car to pickup the alternator (from
PepBoys, $118 rebuilt, lifetime warranty), put it into my old 92 Subie,
and tested the voltage. The battery had already been fully charged.
Voltage was 13.93V so it was definitely above the 12.5V before. It
wasn't the 14.4V that I thought it was supposed to get to but the
battery was charged and I didn't have another person available to rev
the engine while it monitored the voltage to see if it went up.
So it looks okay for the alternator. I drove the old car back to the
car store for the core refund. Smelled something. Nope, not the
alternator (I've smelled a burnt alternator whose bearings went before
and it wasn't that varnish smell from the bearings getting super hot and
heating up the windings). It came from one side. Good grief, now the
front right brake is dragging. I put my hand on each wheel (well, on
the wheel cover) and the front right was significantly hotter. Could be
some rust on the slider pins is the problem since the car has been
sitting idle in the car port for 8 months and maybe just driving it some
will get rid of the problem. But just in case, I'm hunting around for a
brake inspection, preferrably free. I'll take it back to where I had
the brake pads replaced last summer. They worked on the calibers
instead of replacing them and one had a rust ring on one of the slider
pins that they had to burnish off. Might be the same problem again.
GMCBOP
