'96 Legacy Outback
but contrary to Jim's claim, there is
it's not uncommon in vehicles with poor roll dynamics.  it hardly ever
happens in vehicles with good roll dynamics.  a flat tire is absolutely
no reason for a vehicle to roll.  ever.
I think we are actually in agreement here. Your first assertion wasn't
that vehicles with poor dynamics shouldn't flip. It was that flat
tires don't ever cause roll-overs. Ever. Or something like that. I was
merely pointing out that vehicles with flat tires do flip.
I've seen it happen to a car with a low CG and good suspension design.
Not only in roll-center placement, but also in damping. It was not
underdamped in rebound, which causes the bounce back you speak of. It
also didn't lean excessively in turns. It was an Sti, and it debeaded
a rim going from dirt to a road going over a two or three inch hump
while sliding sideways. It wasn't until the next turn-a tight 90° turn
on pavement-that he experienced massive understeer, put on more
steering until pretty much at lock, then snap! The car flipped up and
over that wheel and did more than a complete roll before smacking the
ground again. Rims can dig in when they have no tire.
On a different note, this thread reminds me of an article I read about
a mid nineties Accord that went over a million miles. It still had the
original exhaust. The car's mechanic attributed that to "Keeping the
toxins in solution. Let it sit, and all those toxins come out and get
you."
And to counter that... I bought an 84 MR2 that had sat for 3 years and
had been bought as a parts car. I put four tires on it (Because they
were bald and three different sizes in four different brands.) fixed a
vacuum leak, repaired a bent suspension part, put a windshield in it,
and was good to go for under 1600 bucks. Other than needing an
alternator a few thousand miles later, that car never gave me a lick
of trouble for another 20k miles.
But then there's the guy that bought a 69 911, and on its maiden
voyage after lots of body work lost the brakes when more than one
brake hose ruptured. More body work followed. Or my friend who did a
total restoration on a 914, including rebuilding the engine, but not
replacing the rubber in the fuel system. He had been driving it for
about two weeks, and had just put the new tires and wheels on it when
it went up in flames from a fuel hose leaking in the engine
compartment. Those magnesium engines go up gloriously once you get
them going. There is still part of that block melted into his parent's
driveway.
Mayeb it's alright to let Toyotas sit, but not Porsches.
Oh, and a new wheel bearing, all done since 2003
You can't get away from those damn wheel bearings. In fact, I have one
going out on the rear of my 98 right now. I can hear the brakes
dragging when I make turns.
my statement was that vehicles shouldn't flip just because of a flat.
ever.
not only is it a perfectly predictable and "normal" operating condition,
it's a condition whose math is well known and that can be designed for.
the only reason they flip is because people like you have been
brainwashed into thinking it's the tire's fault, thus manufacturers have
been able to get away without recourse selling you cheap crap, even
though they /know/ they're selling vehicles which will kill you.
while sliding sideways. It wasn't until the next turn-a tight 90� turn
what you've just described is not what you experience driving on normal
urban roads and freeways - the terrain where these vehicles have been
flipping and killing people. you are correct that dig-in will flip any
vehicle, but that is not the issue here. and it doesn't excuse vehicles
with known instability issues not having crush-proof cabins.
you."
driveway.
they're popularly termed "magnesium", but you'll more likely find
they're an aluminum alloy with some magnesium content - just for
corrosion resistance if nothing else - magnesium oxidizes very rapidly.
and if it had reached auto-ignition temperature, you wouldn't have
molten metal on the driveway, you'd have a smoking crater.
The guy I bought it from reports a 'clunking' from the right rear; a quick
inspection showed nothing wrong with the shocks, although it was raining
and when I say "quick" I *MEAN* QUICK! A shake of the car both sides rear
revealed no noises...
Not an expert, but I know there's two different BHG fail modes depending
on "cam count", and it applies to both 2.2L and 2.5L soob engines:
1) "Stage 1" DOHC of either usually have BHG fails on the cylinder wall
side. Bad news. Usually a total rebuild.
2) "Stage 2" SOHC usually fail on the coolant side. Still not good, but
if caught in time can be repaired reasonably cheap (if $2K is cheap)
I fixed one of the "Stage 2" leaks with this:
http://www.barsproducts.com/1100.htm
!! It WORKED!!!!!!!!!
My 2.2 has the blow hole on the exhaust side... :(
Yup, good old Bar's Leaks, but one of their more advanced/targeted
versions. I've used their stuff for years.
That's good stuff for "mouse milk" products, it actually does work.
"MM" used to be a generic for all the "fix-in-a-can" products, but
someone actually came out with "http://www.mousemilk.com/", so websearch
is poor.
The problem with "mouse milk" is that those products cure the symptoms
but not the cause. There's no guarantee that the BHG will pop another
(and different) leak down the road (as proven, it already has problems).
I got lucky on the BHG on my '00 Outback 2.5L SOHC. The previous owner
did do the "Subaru Coolant Conditioner" thing on the recall, so mine
fell into the 'special extended warranty" (IIRC, 105K miles). It was
close tho, it got caught at a dealer "Service Seminar" at 102K.. whew!
If it hadn't got caught there and gotten a true head-gasket job at S00b
expense, I probably would have gone your route. The only thing is that
you have to watch "the problem" like a hawk. You may find that another
hit of Bar's Leak may work again, or it may need some other "MM". But
sooner or later, the only answer is a "real repair". "Your mileage may vary"
I'm no stranger to "Mouse Milk" repair. Right now I'm limping the 4EAT
auto trans in the 00OBW with "Seafoam Auto Trans Additive". The problem
is the "morning sickness" on engaging forward gears when cold. The fix
itself is simple (just a gummy O-ring), but it's a teardown to do it. At
that point, you may as well have it rebuilt. Rough guess $2k+ USD.
Dumping a can of Seafoam in every 6 months (at $7-12 a can) works for
now. But it also allows me to sock some money away to get an AT trans
rebuild in a year or so...
"Shit this is it, all the pieces do fit.
We're like that crazy old man jumping
out of the alleyway with a baseball bat,
saying, "Remember me motherfucker?"
Jim “Dandy†Mangrum
is poor.
Well, the car is rusting badly, and if I do run it this year, it's likely
it's last. It only has 147,000 on it, and I really like it, but with my
"stable" of cars, comes time to let it go. I'll probably grind, scrape,
sand, bondo and paint for about $150 and run it one more time. Has a brand
new radiator ($18 on eBay!!!!) and runs real good. '89 Coupe. Comfortable
as anything else I have had. Or more...
Supra gets all the Big Money. The others (including the '89) are Work
Cars, and I decided I needed a nice hatch like the '89 or a Sta Wag. So,
the Outback is up next.
Maybe if I quit this job I'll stick with the Scion, the Supra, my van (for
band stuff) and a S00B of one sort or another. I'd really like an Impreza
wagon, but the outback is just right for my bass amp!
I did the MM treatment in 2007 and ran it from Feb 2007 to April, then Nov
2007-April 2008, but didn't run it last winter because of the rust. Still
not leaking!
Perhaps I have been brainwashed and am drinking the koolaid. I am with
you on the fact that cars can be, and should be, designed to be stable
enough to not roll over if they have a flat. I think that I put more
weight on the influence of the ratio of CG height to track width than
you do. I think we can both agree that it would be more challenging to
produce a vehicle with the ratio like the explorer had, and also a
nearly zero propensity to roll over. I think we disagree in how
challenging that would be. I am under the impression that you think it
is easier than I think it is. Perhaps I am accepting the ratio that
they went with too easily by justifying it with claims that lowering
the vehicle makes it less off-road-worthy. Maybe that is one of the
things that you'd change in the design change necessary to have made
that vehicle acceptable. I don't know. I think we are nitpicking
points now, and the others are probably sick of reading it.
It was a magnesium alloy engine. You are right that there is Al in
there. However, the particular alloy used by Porsche and VW was AS21,
which is about 97% Mg, and less than 2% Al. In my admittedly limited
experience, I've seen that most Mg alloys have less than 10% Al. One
of my professors used to be the president of SAE, and when I told him
the story about the Porsche going up he commented that it was rare for
the old VW engines to go up in flames like that, but posited that it
may have been easier if it were very clean. I didn't ask for a
clarification on that reasoning, but I'm sure that since the engine
had just been rebuilt, it was clean. Perhaps gunk insulates well
enough to keep temps down? I don't know.
The fire department came and tried water, but that didn't work. They
then said that they couldn't put it out since they didn't have the
foam necessary for the situation. In the end, all they could do was
shoot water at the tree that it was parked near to prevent the tree
from going up in flames. The tree still lost all its leaves on that
side all the way up. (70 to 80 feet)
When all was said and done there was a piece of metal embedded in the
driveway. I could see how you might have read what I typed earlier as
a molten puddle formed on the driveway. Let me clarify. The hot
asphalt was soft enough that a random metal part of uncertain
metalurgy sank into the driveway and once the car was towed away and
the part revealed, it didn't want to move again. It was pretty well
embedded into the driveway.
Have a good one,
Bill
it's not hard to design for stability - it simply costs a little more
money to implement. just like designing to prevent cabin crush is just
a matter of spending a buck or so on the extra material.
the selling price of the vehicle was ~$30k regardless of suspension, so
frod did their famous cost/benefit analysis of lawsuit payouts vs.
projected profitability and decided they'd rather kill a few people and
pay out to the families of the bereaved who had an aggressive enough
lawyer rather than make less money manufacturing a vehicle they knew
would not be a problem. it's only when congress started to pussy-foot
about with "investigation" that frod decided to change their game. they
did two things - fire nasser, the guy whose decision it was, and bring
out the 93 exploder with the updated rear suspension in the middle of
92. yeah, frod knew /exactly/ what they were doing, they just decided
to kill people rather than make safe but less profitable vehicles.
well, those characters may be cast into a block, but i'd need convincing
that it's an alloy number and not a coincidence for the model number.
if i saw "a48" in a cast iron block, it's a big leap to assume it's
specific to the gray iron casting alloy, even though there is one.
those engines "go up" all the time because of the gas leak problem, but
it's /extremely/ rare for auto-ignition of the actual metal to occur. i
doubt it happened.
sounds like a gas fire. you use foam for gas fires - water spreads the
flames.
that it's an alloy number and not a coincidence for the model number. if
doubt it happened.
flames.
http://www.columbian.com/news/2010/aug/05/car-fire-proves-impossible-to-fight/
doubt it happened.
flames.
Here's a better link
http://wn.com/Magnesium's_reaction_to_water_on_vehicle_fire
just a matter of spending a buck or so on the extra material.
so frod did their famous cost/benefit analysis of lawsuit payouts vs.
and pay out to the families of the bereaved who had an aggressive
enough lawyer rather than make less money manufacturing a vehicle
they knew would not be a problem. it's only when congress started to
pussy-foot about with "investigation" that frod decided to change
their game. they did two things - fire nasser, the guy whose
decision it was, and bring out the 93 exploder with the updated rear
suspension in the middle of 92. yeah, frod knew /exactly/ what they
were doing, they just decided to kill people rather than make safe
convincing that it's an alloy number and not a coincidence for the
model number. if i saw "a48" in a cast iron block, it's a big leap to
assume it's specific to the gray iron casting alloy, even though
there is one.
but it's /extremely/ rare for auto-ignition of the actual metal to
occur. i doubt it happened.
Happens all the time. Most of the newer vehicles have magnesium alloy
parts that will ignite.
VERY easy to tell what is burning because it burns bright white and if
you dump water on it the fire will actually get worse.
the flames.
Depends on how much gas and how you apply the water. If you use a solid
stream nozzle the fuel and fire will get pushed around. If you use a
good nozzle with fog you can put out most fuel fires real quick.
The pavement damage happens quite a bit at vehicle fires. Vehicle fires
on newer vehicle get a LOT hotter than on older vehicles, all the
plastics really crank up the heat. However many newer ones do have
magnesium alloys that burn.
We had a Ford P/U about 6 months ago and the mount casting on the front
of the block caught. This was on a dirt road and when we got the fire
out there was a nice puddle of aluminum in the road. Only parts of the
truck left was the box and back half of the cab.
... of my professors used to be the president of SAE, and when I told him
doubt it happened.
When I said, "go up in flames like that.", I meant a real magnesium
fire. He was saying that it was rare the magnesium caught fire, but it
was easier for it to happen if the block was clean. Don't know the
reasoning on this one though.
macunit7957
