On Fri, 20 May 2011 13:11:26 -0700, m6onz5a wrote:
So, I bought a '96 Legacy Outback that has been sitting for about 4
years. It has 157,000 miles on it. Everything looks good, coolant nice and
green, brake fluid a nice light brown color, like brand new, oil a little
dark but not black. Must have been serviced right before being parked.
Now, I know there is a radiator treatment from Subaru that might possibly
keep head gaskets fresh...? Obviously changing the oil is a no brainer.
The car has been started and idled a couple times in the last two years.
What else should I do? And esp about any flushing, like the radiator or
the oil...?
Isn't brake fluid supposed to be clear???
Get the old fuel out of it
Oh, yeah. Actually, he put a few gallons in last year, so adding fresh gas
should work.
Maybe Techron treatment for the injectors. Maybe throttle body cleaner.
(make certain it's safe for MAF sensors.)
I'd very carefully test the brakes - or just put pads and maybe rotors
on anyway.
pads and rotors don't age dude. elastomers do, so you'd be more on
target if you had said "brake seals". maybe.
Don't trust tires if they might be 5-6-7 years old.
dude, i know frod have succeeded in brainwashing a lot of folk into
thinking that their known inherently unstable exploder platform's
occupant deaths were the fault of its tires [they're not - no vehicle
should roll just because of a flat. ever.], but you don't need to be
one of them. a tire that's 5-6-7 years old is perfectly fine unless
it's been sitting in an ozone oven baked under u.v. for that period.
[and no, just sitting out in the sun in your texas backyard doesn't
count.] even if you can see anything, surface stuff doesn't matter
anyway. and you'll note that because they're not keeping their sponsor
out of the limelight for multiple wrongful death lawsuits, the rotting
rubber fairy doesn't encourage you to replace all the suspension
rubbers, shock deal rubbers, vacuum, coolant, hydraulic, fuel and oil
hoses, or all body glass sealants, or all the engine and transmission
seals at the same time.
2-3
drain-change cycles for auto tranny.
IIRC, the coolant treatment is only efffective for external leaks. Mid
90's 2.5 liters had the 'bad' oil-in-coolant leaks.
You may have a point with the brake pads. But swapping them out gives
you the opportunity to wire-brush off any rust, relube caliper pins,
beed/flush the system too.
and her's a snip about tires;
******German vehicle manufacturers (including Audi, Volkswagen, BMW,
and Mercedes) and Toyota began adding warnings about tire age in their
owner's manuals beginning in the early 1990s. They differed a bit, but
the messages were consistent: Tires more than six years old present an
increased risk.
For instance, a Volkswagen manual says: "WARNING: Old tires can fail
in use, causing loss of vehicle control and personal injury. Replace
tires after six years regardless of tread wear. Always reduce speed
and drive cautiously if you must use an old tire in an emergency.
Replace the tire as soon as possible." A Toyota warning reads: "Any
tires which are over six years old must be checked by a qualified
technician even if damage is not obvious. Tires deteriorate with age
even if they have never or seldom been used. This also applies to the
spare tire and tires stored for future use."
European manufacturers developed these warnings based on research
results. For example, the German testing and scientific research firm
DEKRA issued a "special topic" report in 1986 examining tire defects
that resulted in crashes. The study found an increase in tread
separations after two years and a continuous increase from the fifth
through the eighth years, with a dramatic increase in tires more than
six years old. These researchers concluded that consumers should not
drive on tires that are six or more years old, regardless of tread
depth, particularly tires stored for an extended period of time.
The results of another German study concluded that failure frequency
rose disproportionately with increasing tire age . It estimated that a
breakdown of a nine year old tire was eight times as likely as a
breakdown of a two year old tire. The author noted that one reason
"over aged" tires were being sold was the "consumer unfriendly" way
the date of manufacture was coded in the DOT number. The author shared
the results with vehicle and tire manufacturers. ******
more from;
http://www.ammonslaw.com/publications/danger-of-aging-tires
