E
Edward Elhauge
I have a 2002 WRX wagon with the 4EAT automatic transmission.
The problem I have is only during cold weather (32 deg F)
after sitting all night. I'll take off from my drive way
in the morning, going uphill, and try to accelerate hard
to match the speed of possible traffic on a rural highway.
The car engine sounds like it's spinning fast, and the tach
shows the RPM rising past 4000. Meanwhile the car is slowly
accelerating to about 10 to 15 mph. Scary, the way people drive
on that road.
Eventually, after driving 10 minutes or so the problem goes
away. This doesn't happen on warm days.
I was thinking that the problem was in the torque converter
linkage. I would think that the gearing itself would make
some sort of grinding sound if the gears were only partially
meshing. What do people think? I have 90000 mi on the WRX
and would love to find something for the dealer to fix
NOW, before the warranty runs out at 100000 mi.
I found the following post on a 4x4 list and wondered if
I could be experiencing something like this:
Slipping when it is cold often means that the line pressure is lower
than it should be and that can be a result of fluid which is too viscous
or has not been changed recently, plugged filter, dirty valve body
parts, deteriorated rings or seals, and a worn pump.
When I took some transmission classes years ago, the instructor said
always suspect the front pump when this sort of behavior was noticed.
But, as Steve posted, other things can affect it too.
Have you serviced it recently? A service and adjust (if it is one that
has adjustable bands) might be money well spent.
on that road.
Name said:Hi. I am hoping someone can offer some help on my problem. I have a
1996 Ford F-150 truck with an automatic transmission. For the first 5
minutes after cranking my truck, the transmission slips (I guess that
is what it is
called). If I pull away from a stop sign, it will rev up some before
"catching" and going. The fluid level seems OK. This only happens
when it
is cold outside 30 - 40 degrees. It did it last winter a few times
also. The truck has 185,000 miles on it. Any ideas?
