Windshield washer fluid pump leaks
S
StefForester
Hi All,
I just discovered that the windshield washer fluid pump on my '99
Forester is leaking, just a little, with each use. It is enough that I
noticed that it didn't take as long to empty the tank as it used to.
My questions:
Has anyone attempted to fix the seals on such a pump?
Is it better to just pay the ~$55.00 for a new one?
Thanks!
Hi All,
My questions:
Thanks!
If it's like a Toyota, all it is is an O ring.
My questions:
Since the pump seems to be two plastic halves glued together, you sure
the *pump* is leaking? Maybe it's the seal between the pump and the
reservoir tank? You could replace that o-ring or rubber grommet (if the
auto or hardware store doesn't have one, I suppose you could use sealant
in a squeeze tube). Or maybe it's a split hose on the pump's nipple?
If there's enough slack, snip off the cracked end and slide on the
freshly snipped end; if not, replace the tubing.
$55 for a new pump? That must be the dealer's price. Does it also
include installation labor and shop supplies? In my area, Napa Auto
lists a windshield washer pump for a 1999 Subaru Forester for $19/$18
for front/rear, Oreilley Auto Parts for $32/$22, and Advance Auto Parts
for $25 or $22 (they only show the front pump).
Hi All,
My questions:
Thanks!
I recently had to replace the pump on my wife's 03 OBW. I used an
aftermarket one and it came with some wires and a new gasket (like a
fat O ring)
It works better than the original now!
Normally these pumps leak by the motor shaft, back into the pump motor
and out the motor openings.
What I did on the 2003 OB was to buy the after market replacement; after
taking the terminal block from the old OEM pump motor and cutting the
brush holder, soldered the old pump's terminal block to the new pump
wires, so i could use the car's wire harness without modification.
Good luck,
AS
J Hurl
