Whining gear sounds from my Impreza 2014 Sport Premium
Hi Everyone,
I"m hearing a.slight whinimg sound from my Impreza 2014 in front underneath. I"m not sue if this is normal or if something might be happening to TR580 transmission or something else. It goes away when car is warmed up and I don't hear at higher speeds like 40+ mph. It has 89,000 miles on it. I did change the transmission fluid with Subaru CVTF Ii fluid and followed indtructions from AllDAtaDIY and Identifix and have scan tool with transmission tempersture to ensure done correctly. I put in 5 1/2 quarts of CVTFII Subaru fluid.. It was making the sligjt gesr whining sound before fluid change. The fluid was changed at 87,000 miles. Does this slight gear whining sound mean TR580 is going to fail or is starting to go bad.
The following viedos you can barely hear it.
whining gear noise
whining gear noise 2
Any help on this would be greatly appreciated.
I guess this forum isn't very well used. I joined just now to find out some information. I see that you didn't get a response for almost 2 years. I watched the videos but couldn't hear what you are hearing. I guess 2 years later you've probably figured out if it was dying or not.
Hi Everyone,
whining gear noise
Wheel bearings, check & replace them
Moonpie927
