Wheel goes "wop wop wop wop"..
  • Thread starter Dominic Richens
  • Start date
Dominic Richens
Now that it is summer time and we're driving around with the windows open,
especially the passenger side, I notice that the rear passenger side wheels
makes "a lot" of road noise - actually I don't think it is any louder than
the other three, just it is modulated instead of being constant.
Haven't noticed anything different in the handling or wear on the tire, just
had the brakes serviced (though they only change the front pads and discs).
95 Legacy, 169,000 km
Any ideas?
Hi Dom!
Any ideas?
Good chance the noise is being caused by tire tread and/or internal
ply delamination. This might never be a problem, then again it _could_
be a sign of impending catastrophic failure. And usually the failure
will occur when the tire is being stressed, for example when making a
hi-speed lane change or the like; the worst possible time.
I'd get it to a tire shop for a checkup ASAP, and would avoid running
it at highway speeds until it has been given a clean bill of health,
or has been replaced.
And do let us know what you find out. Be safe.
x-no-archive: yes
Any ideas?
What brand and model tires? How many miles on them? Like the previous
poster, I fear a potential impending (and catastrophic) ply separation.
The fact that one tire is noticeably noisier than the other 3 is not a
good omen. Something is wrong.
Have you checked for "bubbles" on the tread ( anyplace on the tire)or
side walls? Are the lug nuts correctly torqued?
You may want to rotate the tires temporarily to make sure the noise is,
in fact, originating from that one tire. This type of noise *could* be
coming from a defective bearing in the right rear axle.
Please have the tires (all of them) checked out thoroughly by a
competent tire shop........... especially if they are Firestone Maypops
or Yoka-exploding -hamas.
Goodyear Allegra, 12,000km (less than 1 year) - just had them rotated (at
the same time as the brake job). I'll take that wheel off tonight and have
a closer look at it and the brakes, and check the bearings are moving in
other the direction they are suppose to :).
If I see nothing, I'll remount it and go for a drive. If the noise is still
there I'll take it to the dealer since they'll likely look at it for free
given they just supposidly did the brakes and checked the tires.
cheers!
