I recently got a '14 Legacy (had an '06 Legacy previously). My '06 had a neat little feature where it was able to show DTCs on the instrument cluster. So, I got curious to see if my current Legacy was able to do the same by doing the same quirky switch and button combinations. It didn't pull up any DTCs, however, it did show these particular settings on the main main screen (between the tachometer and speedometer). The issue is I can't find any information about this anywhere, not even in the owner's manual. Does anyone out there have a limited or premium trim, Legacy or other models of Subaru that have that type of display in the center? I know the ones that just have the regular monochrome display won't show the settings in the same way because I did try this on a base model '14 Legacy and it didn't do the exact same thing. So it may be something that's trim level specific, I'm not too sure. Thanks in advance for any help.
Also, on a side note, my Legacy is not equipped with the Eyesight system, l mentioned this just in case those settings are supposed to be for said system.
