Hello all greetings I have a 2010 impreza with water coming from around the evaporator pipe. The sponge on bottom pipe drips water. I was wondering if it's the seal but the seal is inside but sponge is outside. Does anyone had same issue?
Good morning thanks but it's not the tube, the water flows freely when AC is running but it leaks around the spongeShould be a drain tube under the car. That drain is probably clogged
