water swishing noise from bay
N
neilmccann
Hi All,
I recently had a radiator fitted, all seemed ok for appox 500miles. Now
each time I start engine I hear a swishing of water noise. The noise seems
to come from under the windscreen in the bay. When I rev while stationary
the noise increases. Also when I break I can hear a movement of water. My
heater still works so I dont think its an air-lock. Do these models (00
impreza 1.6) have manual or self bleed valves?
My performance is slightly less but this may be due to a fuel filter
needing replacement.
Can anyone help?????
neil
I had a similar problem with a Toyota Camry. It was kind of a
gruggling noise. The air conditioner had some sort of condensation
tray inside the dash board that had a plugged drain tube. I couldn't
find it, but I took it to the garage and the were able to clear the
tube (which was free - must've been a really quick repair) and I've
never had the problem again.
I hope this helps.
neilmccann said:
Hi All,
neil
Given the new rad fitted, I'd just about guarantee air in the system. It
will probably also slosh on corners. See if there's a nipple on top of the
thermostat housing. If there is, you've got a manual bleed valve. Park
facing UP the steepest slope or ramp you can find (needs to be about
30deg), get it up to temp with thermostat open & heater on full then
slowly open it & wait 'til no more bubbles come out. Close off & top up
tank. Plan B if no valve is take the rad cap off when *cold*, jack car up
to 30deg plus and repeat proc. Cheers
