Mainman said:
I just bought a 2000 Outback Sport. Water is repeatedly collecting in the
spare tire well. Interestingly I had test drove a 2000 RS at a dealer that
had water in the spare tire well also but just put it down as a anomaly.
Anybody know about solutions?
Depends what's causing it: heavy rain? washing with a hose? automatic car
wash? immersion in a river? (Avoid the last one at all costs!) Likeliest
is either an ill fitting hatch seal or latch, or maybe a leaky light
housing or body part - partiuclarly if it's been repaired. First off
-check that the hatch seal is fitted properly, then check that the
tailgate is latching securely. If it's still leaking, fold the back seat
down, climb into the load area with the spare and carpet removed, make
yourself as comfortable as possible and get someone to spray all round the
back of the car with a hose or a pressure washer. When you see water
inside, track it back to its entry point.
As a last resort if it defies resolution, get a Saab drain plug (like a
normal grommet, but with a drain hole in the middle, put the right sized
hole at the lowest point of the boot floor and insert it. You'll still
have a water leak but it won't rust out your boot! Really though, the only
real problem is likely to be if it's the result of a rear ender and it's
entering from somewhere in the roof or above the tailgate. Otherwise, just
time & patience. Cheers
