John
Hi all, doiing many searches on USMB and looking for info on this problem:
I recently replaced the driver's side axle on my '00 OBW as the inner boot
was ripped and had slung grease all over the undercarriage. It nicely
elimintated the shaking I had on acceleration. Now I have a pronounced
vibration and rumble whan I make sharp left turns at low speeds, like when
you pull into a parking spot.
I did notice when replacing the axle that the boot on the left tie rod was
ripped and had receeded (sp?) so on left turns it was exposing the joint
that the boot is supposed to keep clean and keep the grease in. Would this
be the cause?
My thinking:
-the ripped boot has allow dirt and water in and has worn whatever joint is
there. I am in the salt belt (MA) but I dont know how long the boot has
been ripped
-no lubrication
- the ripped boot is now disconnected from the outter tie rod and maybe
allowing the rod/steering to over-extend itself on left turns and causing
too sharp of an angle for the suspension and steering
Oh yeah, right turns act normally, no issues.
Ideas?
be the cause?
My thinking:
been ripped
-no lubrication
Ideas?
