1) Is the Turbo OEM?It just started acting like this after 1500 miles.
The engine is in the car pictured.
My thought is running a higher-octane fuel would be my first theory. I know manuals say that 87 octane is ok and the car will run, but getting the peak performance (horsepower and torque) premium fuel is required.
I would try a tank or half a tank to see if that solves the issue.
Vacuum lines would be just to check and make sure they are all secure with no leaks.
Have you run a diagnostic test yet? (Scan Tool)?
Also what is the RPM Redline? This is probably governed so it may be slowing you down by preset defaults.
You bet! Let me know what you find out...I do appreciate any and all suggestions because they get to thinking outside of my box a bit.
