MYsubaru1986
My 1986 Subaru is using transmission oil, but does'nt seem to leak out onto
the ground. The engine oil level is high and I think the transmission oil is
entering into the engine. The coolant level is good and clear. There was
white smoke comming out of the tail pipe when I put new coolant in the
transmission. After driving around, the smoke went away. It only smokes when
applying power on hills. What can be the cause od this?
