john
The torque setting given in maintenance manual for oil drain plug is
measured when the plug is coated with oil, or when it is dry?
I hope it's the first case, because there is no easy way to remove all oil
from the drain plug and the drain hole.
On the other hand, if the figure given is measured when dry and I follow it
without cleaning off the oil, I would end up overtightening the plug.
What's the correct thing to do?
