Torque Specs Uknown
Mike Lloyd
Installing an "anti-lift" kit and end-links at the same time -- '05 WRX.
I'm looking for the torque values for:
bolt at the end of the Transverse Link
Subframe bolts (12mm & 14mm)
Rear endlink nuts/bolts.
Front endlink nuts/bolts.
In fact, does anyone know where I can even find the maint. manual? I've had no luck thus far.
Mike
I have the "backup" copy on cd in pdf format :) you can get them on Ebay for 10
bucks shipped.
Hi Mike, All!
Here are values from the 2K2 service manual.
The manual says they are 8mm, 10mm, and 12mm bolts, with tork specs of
25ftlb, 52ftlb, and 41ftlb respectively. Odd that the 10s would have
a higher spec than the 12s, but it's right there in black&white, _if_
you believe the book.
The swaybar end link bolts are 33ftlb, the mounting bracket, 18ftlb.
Seems like one of the bolts on the front end links was smaller
diameter on mine, If yours is like that, I would only tork the smaller
bolt to ~25ftlb.
The bolts that mount the rear control arm bushing (ALK), are 184ftlb,
(Yikes! That seems awfully high, but that's what it sez. _I_ wouldn't
go more'n about 75-80ftlb. Use your torque wrench and see where they
break loose.) and the locking nut on the rear of the control arm,
140ftlb.
Be sure to load the suspension before tightening this hardware. I
lowered my car onto 4 cinder blocks, so as to have room to slide
underneath, and tightened everything as much as possible while laying
on my back. I then lifted it again to finish tightening the large
fasteners. I didn't use a torque wrench, but as it took everything I
could muster to break them loose, I got them as tight as I could upon
reassembly. I also used a dab of loctite on the CA bushing mounting
bolts. Again, I don't think these were anything like 180ftlb; I'm just
not that strong. I'd have guessed 100ftlb tops, but, as always, use
your own discretion.
It's a 2002 Impreza manual, but if it's of any use to you, here ya go.
http://chester.uccs.edu/wrx/WRX_Manual/
It's 8 files, in .pdf format, and they're rather large, but help
yourself. There may be other stuff of interest there
(http://chester.uccs.edu/wrx/); you'll just have to look around.
Hope this is helpful. You'll like the ALK if you drive aggressively.
Remember that the ALK bumps you into SM if you autocross, and, alas,
it _is_ pretty visible if your competitors know what to look for . . .
Hi Steve
great manuals !! thanks !!
Do you have / know such manuals for the Forester ?
Regards,
Wilco
Hi Wilco!
Hi Steve
You're most welcome. I'm sure the manuals exist for the Forester, but
I don't have them. If someone out there does, and will send them to
me, I will be happy to make them available on my server.
FWIW, the Forester is built on an Impreza chassis, and I would expect
that much of the nfo in the Impreza manuals will apply.
PS Wilco, from .nl land? . . . Not, by chance, Wilco from R.B.P.?
S said:
Hi Mike, All!
bolt to ~25ftlb.
140ftlb.
I'd strongly suggest investing in a set of ramps instead of using cinder
blocks to support the car or maybe a combination of cinder blocks and
jack stands just in case. Ramps work great for loading the suspension
for sway bar mods and such. Working in construction has turned me off
to the idea of supporting my car with cinder blocks, they're a last
choice in my book. I've seen them break pretty easily.
