I see no reason to consider any single pressure ideal for the majority
of drivers due simply to the fact that vehicle use can be so
dramatically different from day to day, week to week. Of course it is
unreasonable to make adjustments to pressure every time the car is
used - so the practicality of the issue lies somewhere between
considering the 'door/manual' pressure as a good minimum cold pressure
- probably yielding a comfortable ride and decent, fairly even wear
with good handling for average driving, and the sidewall pressure being
considered the max cold pressure (though the engineers probably have
a huge safety margin built in)useful for a heavily loaded vehicle
driving at high speeds (this includes track day as well as moving day).
There are a lot of folks with plenty of experience using slightly
(5-10%) higher pressures than the recommended number from the manual
and they experience no significant wear problems. Perhaps a silighly
harsher ride sensation. That is my experience anyway. Even on my one
track day, I was under the max pressure on the sidewall.
It's better to UNDERSTAND what tires and the stuff related to them are
all about rather than blindly follow a static number for something as
dynamic as automobile tires. Considering what they have to do and the
environment/punishment they endure - they are amazing objects really.
(where does all that worn off tire rubber from millions of cars go? hah!)
tires are amazing indeed.
but they are much much more likely to fail due to
underinflation than overinflation. the higher the
pressure, the smaller the contact patch and also
the less flexure the sidewall must endure per
rotation. the latter is what causes failure due to
underinflation, the sidewalls overheat and rupture,
usually catastrophically.
the only downside I can
imagine of running 10 or 20 percent higher than
(or any increase so long as it does not exceed
the tire's maximum marking)
the vehicle mfgr. recommendation would be
accelerated wear in the center of the tread,
and obviously a slight decrease in absolute grip
due to the decrease in contact patch area.
often the vehicle mfgr. will recommend a pressure
that is lower than that which provides maximum
grip, sacrificing this for improved ride. in hard
cornering, the lower portion of the tire is bent inward
dynamically as it rotates. this too causes heat buildup.
if the pressure is below optimal (and assuming
the suspension is doing a reasonable job of
maintaining proper camber) the tire will bend so
much that the "good" part of the tread is no longer
in contact with the road. in the extreme the sidewall
will begin to make contact. this is obviously not
ideal or even safe operation.
I would not recommend running more than the
maximum value molded into the tire itself.
the tire companies know what they are doing.
I use their maximum as a starting point and adjust
downward.
YMMV
