- Joined
- Aug 1, 2022
- Messages
- 6
- Reaction score
- 1
I have a 2012 outback with the such 2.5 in it. I am sort of in the middle of a timing belt job and I think something is wrong. I set both cams and the crank pulley with all mark aligned just perfectly. The new aisin belt with its 3 marks went on perfectly and all bolts for all the spiny things were torqued to 30lbs. Every YouTube video I’ve seen says to crank it by hand 2 full turns to see that the belt will line back up correctly.
Those marks did NOT line up correctly. Another video says if it’s cranked over 30 times it should line up. I’m in Florida. Needless to say I have hand cranked that engine over many times (lost count) and the belt marks and pulley marks are still not lining up. I look every time the dotted line gets close and all I have is a sweat soaked shirt to remind me of what seems like a failure.
I don’t know if I should hear pistons and valves colliding from being off as I turn it over, but I don’t.
Can someone tell me if this is ok to finish reassembly and just drive it, or take the belt off and reset something?
