R
red75
I just replaced the timing belts on our 92 Loyale 1.8 had a few
problems but got it done. When the car died the first thing I did was
pull the distributer cap because I had a problem with the screw coming
out of the rotor once before so I thought that might be the
problem.The screw was in the rotor but it wasn’t turning so I thought
maybe the gear on the shaft had broken or come loose. I pulled the
distributor but everything looked OK. Thats when I found the broken
timing belt. Anyway got everything fixed put back together but now I
need to set the timing.My Chilton manual says to make sure the idle
switch is ON (?) and to connect the green test mode connector which I
can’t find anywhere. They’re are three connector’s behind the fuse
panel white,pink,green but all three are already connected.I don’t
think these are the one I’m looking for but I can’t find another green
connector. Can anyone tell me what I’m driving myself crazy looking
for. The car is running but it’s kind of sluggish. Thanks for any help
you can give me.
you can give me.
