Mark
Hello Usergroup, You all have been a great resource. I have another one
for you that has me baffled. Something with the brakes/suspension/steering
mech. My 1999 Forester gives a slight shimmy with feedback through the
steering wheel when braking. I've been told that the rotors need to be
turned (I've got new pads tho). 104K miles on it now. This makes sense but
there are a couple of other things wierd.
1- When braking you can hear a slight "Thud" sound when you
first depress the brake and it has been more than a couple of minutes since
you last braked. Doesn't do it when sitting around -just when driving.
Sound is not pronounced but seems to be from the front. My auto mech said
he couldn't hear it a few weeks ago- so he couldn't offer anything as
source- but it is more distinct now.
2- Also a few weeks ago this one showed up. When you are
driving very slow, like turning into a 90degree parking space and you give
the wheel a hard turn to make the turn you can hear a rapid "Thumping" noise
from the steering and feedback into the steering wheel. It's pretty
noticeable, maybe thumping at about 3 or 4 thumps per sec. Happens when
turning either direction and your turning hard (doesn't have to be up
against the limit tho).
The next one is probably not Steering/brake related.
3- Another thing is with the car at idle or on shifting from 1 to
2 , sometimes 2 to 3 you hear a high frequency rattling
noise-intermittently- it's not always rattling. My mech said it was the Cat
converter and replaced it. Problem seemed to go away then showed up again a
few weeks later. He "tightened" up the heat shields and it went away for a
couple of months. One more "tighten" but it ain't gone now. Now I'm Not so
sure it was the Cat or the loose shields.
Looking for any suggestions so I don't get burned (like on a Cat
Converter). Thanks, Mark
