The Knock Sensor
A
Anom
97 Legacy 2.2 I have a P0325 Code. Sensor reads About 560k to
ground. After reading the previous posts sensor sounds like it is good
electrically. What does the code indicate? That I had knock at some point?
I guess I will remove it and clean off the contact surface and reinstall?
This is a used car we just picked up , I have not driven it hardly at all.
It is my daughters. I just plugged in and read the code. I did clear the
code but it came on again. She is certainly using 87 octane gas.
My Haynes manual says, "To check a knock sensor, disconnect the
electrical connector and check for continuity between the sensor
terminal and ground (engine block). Continuity should not exist; if it
does, replace the sensor."
I had the same code in my '96 Outback 2.5L. I came to the conclusion
that at about $42 for the Subaru part, it was reasonable to replace it
and see whether the problem was fixed before paying the dealer to
diagnosis it. The code indicates a malfunction in the knock sensor
circuti which includes the sensor, wiring and connectors back to the
computer and the computer itself. Other's have experienced trouble with
the knock sensor, so there is at least a reasonable chance that it is
the sensor itself rather than the wiring or the computer.
Ed P
TLamb
