A
aiiadict
I'm doing SPFI conversion to an EA81... going to the Junkyard every
day.
1986 and 1987 2WD GL wagons, sedans, and 3-door coupes (excluding XT
and turbo)
1988 and 1989 GL or DL wagons, sedans, and 3 door coupes (excluding XT
and turbo)
1990 through 1994 Loyale models (excluding 1990 turbo)
there's the models of Subarus that will work. WHERE is the fuel pump?
I found an 86 GL wagon... traced the lines to the back. I look in
front of the passenger
side rear wheel. I see the lines going through the frame.
I look in the back deck area. There is 1)an access panel to the tank
(near the middle
of the vehicle, on the back deck) Is this the pump? or the level
sensor? or both? I also
look at the wheel well cover. Right behind it is a small access
panel. I open that
up with a 10mm wrench, and find 2 fuel lines, a two conductor 12 wire
harness, but
no pump... it disappears once again into the frame.
Do I have to pull the tank?
Rich
day.
and turbo)
and turbo)
(near the middle
panel. I open that
harness, but
Rich
