P
Paul B
As for the subie oil drain plug gasket get yourself a COPPER WASHER
from OIL-TITE instead!
It is their part # 65277 (M20) and it fits almost every
Subaru model having a 20mm oil plug. I have used these copper
washers and never had one drip of oil on the driveway. Best of all
a package of two cost me only $1.29 at my local Napa Auto parts
store, and you can even use the same oil ring a second time by
simply turning it around (flip it 180°) and the other side of the soft
copper will kiss up to the oil pan with a snug seal!
(Oil-Tite M20 Copper is in
a black pegboard package that's a little bigger than a business card. )
If you want to DIY one, just get a piece of 1/4" copper flat sheet and
punch out an ID ring using a 20mm circular punch and an OD using a
25mm circular punch. You then have a ring with an ID of 20mm and
an OD (wall) of 25mm (OD can be bigger up to 30mm) Just use the
soft copper and don't over-tighten it. Just snug it up and you'll be OK.
Been doing this here with DIY copper rings on the oil pan
for 2 years as drain plug gaskets with no problems.
