simian said:
My 1994 Subaru Loyale will no longer engage into 4x4 mode , depressing > the button on the stick fails to elicit any response( the display on > the dash will not light up) this occurred quite recently and I have > never had any problems prior .Could this be a simple electrical
problem?
The light on my Loyale has a mind of its own. It will work for a while,
then go on "hiatus" for months before it decides it's going to work
again. I don't remember how I discovered this, but a shot of contact
cleaner into the gap around the switch in the top of the shift lever
sometimes revives things.
But, even when the light's on vacation, if I turn off "noisy" things
like the radio and heater fan, I can hear a faint "click" from under the
car as the 4wd engages. Can you hear anything?
My system (it's a '90) is vacuum operated, and there's a small vacuum
line that operates everything from a dashpot near the front of the
gearbox. It's hard to see (gotta crawl under there and look carefully w/
a good light) but it's a place to start looking if you DON'T even get a
"click."
Good luck!
