F
Foril
Hi
Would these fit on my subaru impreza outback 2002
Goodyear Ultragrip 5
205/65R-15
Thanks
Pat
205/65R-15
Thanks
Pat
205/65R-15
Hi
205/65R-15
Thanks
Pat
How low can you go, with say an Impreza? There has to be a limit
somewhere where you compromise dry pavement handling. 185 is pretty
narrow....
Nicolas Dore said:worth repeating). The Tirerack gives your tires as 205/55-R16. Putting
205/65-R15 on will throw your odometer off a bit. How much?
Found a site (http://www.powerdog.com/tiresize.cgi/) which gives
circumference for tire sizes. Using a 65 instead of a 55 will see the
circumference grow from 75 to 80 inches, or 1/15th, or ~7%. Going 100
mph on the odo will actually be ~107 mph. You would need 175/65-R15s
to have the same circumference.
Nicolas
Date: 8/28/2003 4:00 PM Eastern
(e-mail address removed) (Foril) wrote in message
Hello Pat
You can find the tire size on the side of your tires (obvious but
Nicolas
