Subarau Outback 2005 & XM Satellite radio?...can't get it without crappy FM modulation!
S
Stefan Kozlowski
Folks,
I just bought an Outback Limited 2005. I love the car but have been
quite annoyed to realize that I can't get an XM satellite radio
installed without using crappy (non-radio-connected) FM modulation?
I went to my local Tweeter and bought a new XM Commander unit and
scheduled an installation date. I was going to place the Commander in
the center dash opening above the current CD changer. I dropped the
car off and returned two hours later only to be told by the install
tech that the installation was impossible with the 2005 factory radio.
The tech said that Subaru had changed the radio antenna hook-up and it
now sported a funky new connector which wasn't compatible with any
current XM or Sirius FM modulation units. Also, there were no direct
AUX inputs available because of the standard 6 CD changer already
attached. Tweeter claimed that the local XM rep actually came over and
looked at my radio and promptly called corporate in an effort to make
them aware that there is an entire class of car which won't work with
existing XM hardware. The Tweeter tech claimed that within six months
or so, someone "should" come out with an adaptor but until then, I was
out of luck.
This left me with no real options. External FM modulation (not
connected directly to the radio antenna) isn't a valid solution for
me. I live between Baltimore and Washington and between these two
markets, the FM frequency spectrum is totally flooded. Hence, when I
initially tried to go this route in my old VW Jetta, I was constantly
getting bleed through from broadcast stations and had to retune the FM
modulator constantly. I even bought a relatively expensive C Crane &
Co. FM transmitter and still experienced bleed through.
Has anyone else run into these problems? If so, did you find a
reasonable solution? The thought of not having satellite radio for the
next six months is killing me.
If I had known this problem was going to surface, I would have spent
the extra 5k and gotten the Audi Avant! ;-/ Nah, just kidding.
--Stefan
Sol'n is to reaplace the head unit if it hurts that bad to be w/o XM radio.
ENS Mike Lloyd
NAS Pensacola
850.384.5080
Got a friend into amateur radio? Or maybe a CB
repair shop (check around the back of larger
truck stops)? It wouldn't be too difficult to do
a hack & solder job, replacing the XM plug with
the Subaru original plug.
My new 2005 subaru outback limited is due to arrive at my local dealership
by mid sept. I'm a Sirius satellite radio fan and wrote Subaru to ask
about installation. They basically gave me a non-answer saying they would
forward my letter to their technical dept. That was about 3 months ago. In
the meanwhile I've been looking at this link.
http://www.jpcustoms.com/store/customer/home.php?cat=306
I would not want to mess up my new subaru's audio system with a
"brute-force" approach so I am determined to find
a non-invasive workaround. I don't want the FM modulation either. When I
get my new subaru and get something working i'll post my solution. Until
then, try the link above and let me know if you come up with anything.
I wanted to install MP3 to my new Outback 2.5i Limited (car rocks!). While 6
CDs are good, MP3 is far better. I went to high end shop (Magnolia High Fi)
and here is the story:
as of today no after market radios can be installed due the integrated
climate controls, etc. They can manufacture custom face plate to match the
original one, for extra $600. However they said, in about 6 mo some 3rd
party will come up with the custom face plate and it will be cheap. At least
this how it happened with the Ford Focus and it's stupid oval radio.
so I am holding on to my old MP3
Get yourself an XM Commander. The WIRED FM Modulator is great, sounds
excellent.
I have XM & Sirius; if you care about the music you're going to find
XM is much better, and Sirius is like FM without commercials (500
track playlists, vs. XM's 4,000 track playlists on some channels).
Have you tried www.crutchfield.com and select "What Fits My Car?" under
"Car Products" and that will take you to Crutchfield Vehicle Selector
which lets you put in the 2005 outback and displays a list of compatible
audio and video products that fit? I haven't actually purchased anything
through crutchfield and I'm curious as to whether these items will work
without the hassles you described.
http://www.crutchfield.com/S-BLz9GukkwOL/cgi-bin/autoinfo/autoinfo.asp?lp=
They also have a toll free number.
