Still have 96 OB problems
R
RAJP53
167K miles on my 96 OB. Runs great EXCEPT for two things:
1-The CEL going on within 70 miles after reset and the $%^& temp gauge. The
last time the mechanic reset the CEL he said he cleaned something out but I
don't remember what (he's not available for me to inquire).
No detrimental codes, gas cap is fine. Why the CEL?
2-The temp is fine and the gauge remains in the 8:30 position...EXCEPT if I
stop. It will remain in the 8:30 position until I start to accelerate again.
The gauge will run up to the 10:00, 11:00 and even the 12:00 positions and then
drop down. The car will not overheat. One mechanic at Subaru told me that
antifreeze is mixing into the gas and I should cut my losses. That was five
months ago. I do often add antifreeze.
Again the car does not overheat. One mechanic used a laser thermometer and
told me that the temperature was fine. Another told me that there could be air
in the line.
One last thing: I installed a K&N air filter.
Why the gauge problems?
Thanks to all for the advice.
Ric
Try looking into the overflow tank (not the radiator) while the engine
is fully hot and idling, and see if there is any gas bubbling up.
Is the oil chocolate brown by any chance?
Not brown but coffee cream.
sounds like head gasket!
If it looks like chocolate milkshake, its usually a head gasket (or other
leak) letting water into the oil. Are you having to top up the radiator
water at all?
In answer to the question "Are you having to top up the radiator
water at all?", Yes, I have to top up the radiator with anti-freeze about once
or twice a week. If it is the head gastket as "a"a@hotmail suggested, what
kind of job is that? Is it worth repairing in an otherwise good running 167K
miles 96 OBW? Thanks so much for the advice.
That job is expensive because it requires removal of the engine. Once the engine
is out, you might as well replace it with a refurb or a used engine with lower
mileage. The 96 (2.5l I presume) was the first year of that engine on the US
market and could be quirky - they changed quite a few things in the 97 - 99 DOHC
model.
Whether it's worth it or not - that depends on
a. whether you have a good mechanic with affordable rates.
b. the condition of the rest of the car.
96 is by no means old for a Subaru, but at 167k, you've got to also allow for
axles (CV joints), wheel bearings maybe a new cat (exhaust system) in your
budget.
florian
AMARIAL
