DK said:
This thread leaves me wondering - what exactly *are* advantages
of alloy wheels if any? There are a lot more expensive then steel,
so there has to be something that justifies spending that much
extra money? My list of what I can think of:
Extra money?
In last year I saw cheapest alloys have almost the same prize as steel rims.
- Lighter. Are they really? How much of a factor is this driving
a normal car?
No, they are heavier. For a normal car probably no difference.
- Don't rust. Are there really 10-15 years old cars where wheels
are compromized from rust?
Alloy wheels also rusts, especially cheaper ones - from salt in winter -
they have internal corrosion, not visible, after few years they can break
down suddenly. (Some are "certified" for winter use.)
Definitely yes.
- Heat dissipation. Again, how much of a factor is this driving
a normal car?
For a normal car zero. For sporty maybe some.
- More uniform to begin with and better keeping their shape.
Perhaps that makes alignment easier or suspension lasting
longer?
Alignment (balancing) easier?
No, more difficult and more expensive.
Suspension lasting longer?
No, they are harder so suspension suffers from that, especially if you use
bigger rims and lower profile tyres (So they are also less comfortable). For
profile /60 and higher will be no difference.
Handling better?
Yes (especially with bigger rims and lower profile tyres). For profile....
(see above)
It is also more probable that you deform (permanently) alloy wheel so add
further $s for aligning.
I think steel rims are not usable for extra low profile tyres - must be used
extra hard (and expensive) alloy wheels.
Did I forget something?
Conclusion: for normal car and driver it is only a fashion, for more
demanding driver it has a sense, but only with low profile tyres.
