Starting up after 2 yr break
T
Tana
I have a 89 Legacy that I haven't used for 2years.
It's been in storage.
This is what I have been told to do but I wrote it down quickly...
1 - Remove plugs & squirt oil into each cylinder.
QUESTION(Are we talking regular oil or WD40?)
2 - remove coil lead from distributer & connect to metal part of engine.
3 - Turn engine over 3-4 times for 2-3 seconds
4 - Then turn over for 10 secs three times - wait 1 minute between tries
- should see oil pressure rise on gauge during this phase.
5 - Connect up plug and coil leads and start up. Should smoke for 10mins.
QUESTION(does that mean the sparkplugs have been out for all this time?)
Does this sound right?
Any thought on my nervous questions?
Thanks T.
4 - Then turn over for 10 secs three times - wait 1 minute between tries -
Thanks T.
I was told the initial turnover should be by hand.
And watch you don't hydrolock that engine (say bye bye to it if you do).
Sounds good to me. Use motor oil and about 10 cc per cylinder. Leave
plugs out during cranking.
Thanks Edward, appreciate your help.
Cheers Tana
I believe the main thing you want to do is remove power from the
injectors... if your car is EFI... or basically cut fuel in some way.
Ignition doesn't matter too much, no fuel = no fire, and no fuel = no
possibility of flooding the engine.
Use regular oil, just a little bit of it though.
Here is a thread with a bunch of relevant info -
http://www.rs25.com/forums/showthread.php?t=50882
Sorry another question.
Would 10cc be equivalent to about a teaspoon (5mls)
Tana.
No injectors on this model.
Thanks for the articles, they were really helpful
- the turkey baster it is.
Edward suggested 10ccs of oil which I'm guessing is about 1/2 to 1
teaspoon?
Many thanks,
Tana
You should not ground the coil lead, put it close to a metal part, but
do not short circuit it.
You may need to replace the fuel in the tank, depending on humidity, how
full the tank is etc.
I would replace the oil and filter. Then after spraying the cylinders
with oil, crank the engine without the sparkplugs.
Good luck
Good luck
Likely the pressure in the rails has dissipated - expect longer cranking
to pressurize the fuel system. Probably not much depending on how long
you wait between turning it on and cranking I guess.
rssaasssa
