squeezing sound in a sharp turn
A
akyunt
Recently, my outback 2000 is giving a pretty loud squeezing sound when
I do a sharp turn. The problem is worst when the car is just started,
and there is no sound once it warms up. I am going to a mechanic soon.
I really don't know much about cars and I would like to have an idea of
what the problem could be in advance. Thanks.
I do a sharp turn.
Squealing?
The problem is worst when the car is just started, and there is no
sound once it warms up. I am going to a mechanic soon. I really
don't know much about cars and I would like to have an idea of what
There's a lot of load on the power steering hydraulics when the wheels
are racked hard one way or the other. This load could be causing
slipping of a belt somewhere. As the belt heats up, it adheres to
pulleys better and that could be why the noise goes away. Or the
hydraulic fluid gets warmer and less viscous.
Another source of a noise in sharp turns would be low tire pressure
and tire squeal.
No idea if either of these apply based on your description, but I'd
put them in the realm of possibility when the mechanic gives you a
diagnosis.
Thanks for your reply. The steering fluid is not low as it was checked
during the last oil change. I remember the mechanic changed a belt in
the last tune-up. It could be the belt was not put very well. I forgot
to mention that when I turn on the AC as soon as the car is started,
the noise gets substantially louder even without turning the steering
wheel. So, I believe your suggestion is right and probably the AC belt
is slipping.
Staff online
Scott-PNW
