V
Vanguard
Vehicle info: '92 Subaru Legacy L wagon 4WD non-turbo
Sometimes when I start my car, the exhaust is far too rich and detonates
back in the catalytic converter. When it happens seems sporadic. The
weather could be cold or hot, humid or dry, and the car may have been
sitting for several days or only for 4 to 8 hours since the last time it
ran. I can compensate by shifting manually to keep the RPMs way up. When
the problem arises, I have to keep the RPM up to around 2500 when at a
stoplight (so it doesn't peter out). When I take off, I'll put it in first
gear and shift manually to keep the RPMs up high; otherwise, it will
hesitate on acceleration and I hear the detonation in the exhaust system.
Even after the temperature guage shows normal level, it is only after it has
been at normal for about 15 minutes before the over-rich problem fades away.
It only runs overly rich occasionally.
The other problem is that the "Check Engine" light comes on sometimes. I've
had it in the shop 4 times to have them read the codes. The first 3 times,
they got no error code. On the 4th time, they got no error code but when I
started my car to leave then the "check engine" light came on and they
hooked up while the car was running. I don't remember what was the code but
it didn't make sense at the time and the mechanic said it was wrong. When
the "check engine" light comes on is *not* when I have the first-startup
overly rich mixture problem. They seem to be independent symptoms but maybe
not. I suppose the "Check Engine" light might not be coming on but the
computer is still screwing up the mixture when the car is started.
So my choices (that I can figure out) is to replace the engine computer
and/or the oxygen sensor. I replaced my exhaust system about 4 to 5 years
ago but they reused the original oxygen sensor (they were going to replace
it but couldn't get one at that time). As I recall, this sensor check how
much oxygen is in the exhaust and recirculates a portion of the exhaust if
the oxygen is too low. Well, if it is running overly rich then wouldn't the
oxygen level would be low?
Any opinions if it is more likely the computer or the oxygen sensor screwing
up the mixture (so it is sometimes too rich on startup)? Might it be
something else? Besides the 4 times to take it into the shop to see if they
can nail the cause of the "check engine" light coming on (but never finding
anything), I've even left my car at their shop over the weekend to let them
start it cold to see if the over-rich problem crops up, but it never failed
when they had my car.
