Shutting the Engine while moving slowly
My Subaru Forester Cross Sport 2004 model keep shutting down while the car is moving slowly and sometimes refusing to start. In addition, it also has jerky shaking when i turn right from a full stop. I need help with the diagnosis.
Could be caused by lots of different things. Try to isolate it down to the lack of fuel, spark or air first.
What he said. What have you looked at so far? If you don't want to actually diagnose (no one does these days...) you could look at some easy stuff.
SLIGHTLY ( like 20-MPH-Equivalent-Foot-Feed ) depress (and HOLD-!) Gas-Pedal , then try to re-Start : if this works , then it is your Fuel-Control-SYSTEM ... !!!!
That will get you into the correct World of Problems ... !!!
Does it supposed to start or not? Great info but I'm just not clear on the results. "Works" can mean many different things.
awsmdad
