Scraping noise in rear
E
Ed P
I have a '96 Legacy Outback 2.5L AT with 90k miles that has just started
making a rubbing, scraping sound in the right rear during left-hand
turns. The noise is there for virtually any kind of turn; e.g., turning
from one street into another. Applying either the foot brake or the
parking brake has no effect on the noise.
It sounds a lot like a tire rubbing a fender but no such contact is
evident. Tires are stock size and have been on the car since 57k. In
trying to determine the cause, I found the rear disc brakes to be 90%
worn so I have replaced the rear brakes and turned the rotors, but the
noise is still there.
I suspect the noise must be either in the wheel bearing or outer CV
joint (CV joint boots are all intact). Has anyone experienced this type
of noise and found the cause?
TIA
Ed P
Dunno, but this subject has Rodney Dangerfield in my head saying
"Whoa! Sounds like you should see a proctologist."
"I get no respect though... my proctologist used to work for Roto
Rooter!"
I had same noise - occured only when turnin - was the reas transfer clutches
in differential - Cost $1200 to fix $600 per side
You say transfer clutches in differential -- was this a limited slip
differential?
Ed P
