Rough Running, shuts off at idle
Seeing what I can look into for this issue.
At idle there is rough running.....even cold it is rough but more so when warm.
With accelerator pressed while warm, it is fine.
I can hook up my scan tool, and if I look at "Roughness Monitor" for all 4. It does show numbers while at idle, when I press the accelerator the numbers go away and smooth running.
So that is misfires in all cylinders.
I get P0300 (no cylinder specific code, so there are misfires on all cylinders)
I have gotten P0068, I replaced the MAF. Same issue.
I took out EGR and cleaned it. Ran tests with my scan tool and that all seems to check out.
What should I look at next?
This all happened at once, so I don't think ignition coil issue for all 4 plugs.
Perhaps Throttle issue? TPS?
Any ideas would be appreciated.
Bobby63
