K
Konyoman
Is it necessary to rotate the tires on my 04 Forester? I have heard that on
AWD cars, it isn't necessary.
thanks
thanks
Yes. I do on my '03. I put off on '98 and had to get a new set at 25kKonyoman said:Is it necessary to rotate the tires on my 04 Forester? I have heard that on
thanks
It is absolutely necessary. RTM.Konyoman said:Is it necessary to rotate the tires on my 04 Forester? I have heard that on
thanks
thanks
thanks
Ernest said:Which tyres wear out quickest, front or rear in a AWD car. Was just
wondering.
on AWD cars, it isn't necessary.
thanks
R said:actually it's almost the opposite
Subaru's AWD REQUIRES that all the wheels be the same circumference within a
few percent... this means that equal wear is imperative - including your
spare
just take take the compact spare with no problem as long as you
don't exceed the 50 MPH recommended speed.
_@_._ said:Rotating tires? They rotate all the time when you drive!
Which is bogus, based on increased stopping distance with compact
spare. Ignore 50MPH rule and increase folloing distance.
I believe you are directed to put the spare on the rear, even if ity_p_w said:I never said there wouldn't be decreased performance. I only meant
that the manual transmission models wouldn't suffer massive damage
because a compact spare is used for a bit. The viscous-coupled center
diff should be able to take more abuse than the electronically
controlled clutch packs. Heck - the automatic with turbo models don't
even have the FWD fuse, and most come with compact spares now.
Just think about it. Automatic + compact spare + FWD fuse needed =
the system will wear out prematurely if the tire sizes don't match.
Manual (or turbo auto) + compact spare - FWD fuse needed = the
system can tolerate some tire size differences of more than just a
few percent.
Basically, the compact spare should just get someone far enough
to get the damaged tire in for a proper repair.
Carl said:I believe you are directed to put the spare on the rear, even if it
requires changing 2 tires to move a rear to the front.
y_p_w said:I looked in my 2004 WRX owner's manual, and I can't find anything
directing that the compact spare can only go on the back. I also
can't think of any way to do what you suggest without jacking up
the car with one flat tire on the ground. I would never consider
doing that.
Really - viscous-coupled center diffs aren't going to die because
of a 1/2" difference in tire circumference.
The sense that I (and many others get) is that Subaru is being
extremely conservative in recommending that tire circumference
can't be more than the equivalent of .03% difference in
circumference. It might possibly be more critical in some
of the automatic transmission models.
Carl said:On page 9-3 of the manual that came with my '06 WRX Wagon (In case of
Emergency, Temporary Spare Tire) I find the following;
"* The temporary spare tire must be used only on a rear wheel. If a
front wheel tire gets punctured, replace the wheel with a rear wheel and
install the temporary spare tire in place of the removed rear wheel."
I doubt I would be concerned about putting the temp spare on the front
if I were immediately going to the dealer/tire store for a repair and it
was withing 20 miles or so. Still, I suppose they have a reason for the
instructions in the manual. YMMV
