- Joined
- Apr 7, 2022
- Messages
- 2
- Reaction score
- 0
Hi all,
I'm new to the forum, and I've been having an issue with the reverse gear in my Subaru 2010 Legacy 2.5 Non-Turbo MT (176k miles) ever since I had the clutch replaced in 2016 (@125k miles). Gears 1-6 work great, but when I try to put the car in reverse, the gear pops out. I've found that if I press the car into reverse and jiggle the shifter right to left ten times, it works. But I would really like to know the source of the problem. I took the Subaru back to the mechanic who changed my clutch, and he didn't fix or diagnose the problem. He also does not have a good reputation, so I don't want to bring my car to him anymore. Both the dealer and a transmission specialist said they wouldn't be able to diagnose the problem without disassembling the transmission.
Any ideas of why the reverse gear would being popping out after a clutch job? Is it possible the issue is unrelated to the clutch replacement? It seems like too big of a coincidence to me. Could something have been knocked out of alignment during the clutch job causing the reverse gear to pop out?
I'm pretty new to DIY auto mechanics, and I started doing work on my Subaru about a year ago (new brakes and rotors, jacked up the engine to replace valve cover gaskets). I'm looking to learn more, and hopefully I can find the source of the problem. Thanks in advance for the help!
