Request Assitance with Vacuum Lines
Hello everyone, new poster here.
I work at a shop and decided to take on the job of a neglected 2005 Subaru Baja 2.5 Turbo. Previous tech swapped the bad engine out for another and mixed up the PCV/Vacuum lines and Coolant lines. I'm certain that I got all of the coolant lines correct, I have put a vacuum on the cooling system and found no leaks other than the turbo coolant line, and am in need of installing the vacuum lines to their correct ports. I have pictures of what I am looking at.
First: Where does this connect to?
Second: Does this go to the PCV on the valve cover on the passenger side?
Third: Do these two go together?
Fourth: Do these go together as well? The vacuum line is goes with the bundle of lines for the fuel injectors.
Fifth: I know it mounts to the front of the intake manifold on the passenger side, but do not know where the vacuum fittings go.
Sixth: What line goes here?
Seventh: (Two pictures) Which of lines one through three goes to fittings one through three?
Eighth: (Two more pictures) Where does this line, the one in my hand, connect to? It goes to a vacuum switch attached to the passenger strut mount, where my finger is touching.
Ninth: What connects here?
Last image to upload.
Does this line from the bottom of the throttle body link to the blow off valve on the intercooler?
Moonpie927
