F
fufuliu
(Sorry if you're seeing this twice -- I canceled the earlier post
because
of newsreader issues, and am reposting from a different account)
I recently bought a used 2000 Outback, and have noticed what seems
to
be a fairly serious problem when shifting into drive. It isn't just a
delay, but will (sporadically, not every time, which is why I didn't
catch it before buying) simply not shift into drive until I apply some
gas, and then it jolts into drive.
This is most noticeable when shifting from reverse to drive, where
if
I let up on the brake, it will continue to roll backward, unless I
hit
the gas, at which point it jolts forward (although sometimes with an
additional brief delay -- I can see and hear the RPMs go up before it
starts going forward, but that never translates into backwards
acceleration, luckily).
As you can imagine, this isn't a lot of fun when trying to get in
and
out of tight parking spaces.
Any idea what might be causing it?
Thanks for your help,
Brian
because
to
if
hit
and
Brian
