Repeatedly blown seals = clogged oil gallleys?!? - HELP
P
PZ
Calling all experienced Outback owners - I need your help!
I have a '97 Outback that just won't stop blowing the crank seal.
It all started (cue sound effect and fade-away visual effect.....) at
the beginning of the year, with 78k miles on it. I had noticed the
classic burning oil smell after long highway drives. The verdict:
leaking cam and crank seals. Fair enough, had 'em replaced, along
with the timing belt, etc.
I came back 2k miles and two weeks (after hitting the highway in a
serious way) later, still having a bit of the burning-oli smell. They
checked it out, said it was residual oil in the crannies of the block
that had to burn off. I wasn't completely sold, but at least had done
due diligence.
Fast forward to the end of June, and 96k miles: The crank seal
totally lets go, big puddle of oil and a tow-truck ride to my shop,
now in a city 400 miles away from the first shop. They replace a
popped-out crank seal, and I get the first shop to refund most of my
money. But it still costs me a fair chunk. Everything looked good
though, over the next few thousand miles: no dropping oil level, no
oli smells. I thought I was all set.
Now, last weekend, I had the SECOND crank seal blow out with attendant
puking of oil all over. Took it back to the same shop. Now they tell
me that the reason seals keep popping is that it's "an older,
well-worn engine, and probably has clogged oil galleys, causing build
up of crankcase pressure." They want to drop the pan and wire brush
clean the oil galleys.
Has anyone ever heard of this? I've looked at the group archives and
know all about the seal issues of the 2.5 engine and the '97 OB in
particular. But I would think that clogged galleys will just
contribute to valve noise, not crankcase pressure.
I want to trust these guys, but it's not making sense to me. BTW,
they won't guarantee this is the cure and say they got the info from
some dealer info-database.
Please post for general education, but also e-mail to the address
below that's really more "hot" than "not". Many thanks in advance.
PZ
(e-mail address removed)
Sounds like a problem with the PCV (Positive Crankcase Ventilation)
valve or system in general.
There is always leak of gases from the compression chambers into the
crankcase. Those leaked gases have to be removed from the crankcase so
the pressure does not build up. In order to comply with emission
regulations, they are sucked back into the intake manifold via the PCV
system.
Check for clogged PCV valve, pinched hoses, etc.
Good luck!
You can also place the palm of your hand over the oil filler tube
(withthe cap off, of course) with the engine idling. If everything is
OK, you should feel a slight suction after a minute or two. If
instead, you feel pressure trying to get out, you know the vent system
is clogged.
