Chicobiker said:
I think I've read about rear bearings going before on this group.
Yes, wheel bearings have been problematic and a subject of discussion in
the past...
I have an old Toyota truck (one of the models that just keeps going and
going) and I've often joked that in building that truck, Toyota scoured
the world for all the "best" design ideas in the automotive world, and
incorporated them. Subie followed behind and took the worst!
Ok, that might be a bit harsh, but they certainly screwed the pooch IMHO
on wheel bearings. Somewhere I read that ONE of the causes of early
failures had been pinpointed as faulty seals that allowed water into the
bearing. Then, in earlier discussions, it was revealed that Subaru was
claiming their bearings were "pre-lubed" from the factory and didn't
need additional grease prior to installation. I haven't a clue how many
bearings WERE installed that way, but after discussions about how little
actual grease there was in these bearings, I dismissed that idea as
bogus, especially after I'd bought a Subie bearing and it had little but
corrosion protective grease on it.
Combine a lack of adequate grease w/ a possible incursion of water
and/or dirt, and the bearing's doomed from the start. As for heat, IME a
properly lubed bearing SHOULD be able to go at least 60-100k miles
before needing attention (which SHOULD consist of cleaning and
regreasing, NOT replacement, again IMHO only.) 40 years of driving in
essentially desert conditions (heat-wise, not off road-wise) tell me a
properly lubed bearing shouldn't fail from any heat we normally
encounter. Again, "properly lubed" is an operative term...
