There's certainly no downside to changing them 'early' (other than
loss of value) and, if the vehicle has seen 'extreme duty' or the pads
are very old, you might change them.
That reads better if you change "loss of value" to just "cost".
If you are changing pads, consider Stoptech Street Performance pads
(got mine from KNS brakes online) or, Centric Ceramic. Put the
Centrics on my wife's Outback and it was an improvement. Put the
Street Perf. on the front of my WRX and they are awesome.
I'm not adverse to using aftermarket performance pads (back when all you
had were drum brakes on all 4 corners, they *always* got changed out to
Velvettouch semi-metallic shoes on any personal vehicle).
But, the OEM Subaru pads are probably the best choice unless you are
really into heavy braking as in real racing. Even the local independent
S00bie specialty shop says the same, even tho they sell and install the
fancy stuff.
What they've seen with putting 'fancy pads' on "daily driver" cars has
been (varies on pad brand & line):
1) Much higher rotor wear
2) Shorter pad life
2) Uncurable squealing (other than "driving off the night-rust" by
riding the brakes)
The *true* OEM Subaru pads are also well-liked by most of the decent
brake and tire shops in this area. I hate to admit it, but I often
listen to the desk folks ("aural shoulder-surfing ?) after they've
written up brake jobs on s00bs, and the first call after the writeup is
to a local soob dealer who does good wholesale parts prices..
(But we know *1 Lucky Texan*, methinks you have the need for 'fancy
Do not neglect flushing the brake fluid if old.
This *by itself* can be amazing. We all get progressively used to what
the brake pedal feels like, and it's hard to believe how we think that's
OK.
I flushed/purged the whole brake system on a Bronco II a few years ago.
There weren't any outright brake fails, but one front-axle brake line
had taken a few too many rock dings, so I replaced it 'just in case'.
I didn't do as good a job on bleeding as I thought I did, so I proceeded
to flush just that corner. The "funky color" of what came out from well
up the lines sorta scared me, so I ended up flushing the whole brake
system. It took over 3 quarts of fluid, but the end result was a much
more responsive pedal.
"Shit this is it, all the pieces do fit.
We're like that crazy old man jumping
out of the alleyway with a baseball bat,
saying, "Remember me motherfucker?"
Jim “Dandy” Mangrum
